Compiling Paraview 3.12.0 and the PV3FoamReader Module |
January 9, 2012, 03:35 |
Sangmin Park
Rep Power: 15 |
I'm trying to install OpenFOAM-2.1.0 on our linux cluster. Our system is running on CentOS 5.5 all libraries are built in the ThirdParty-2.1.0 directory. ParaView is built correctly. And I tried to compile ParaView and the PV3FoamReader Module. For this, cmake is needed and I already installed it in the ThirdParty-2.1.0 directory, ThirdParty-2.1.0/platforms/linux64Gcc/cmake-2.8.7 And I add cmake PATH in my .bashrc file as below. export Cmake_DIR=$WM_THIRD_PARTY_DIR/platforms/linux64Gcc/cmake-2.8.7 export PATH=$Cmake_DIR/bin:$PATH export LD_LIBRARY_PATH=$Cmake_DIR/lib:$LD_LIBRARY_PATH also, I add ParaView environment variables in .bashrc export ParaView_DIR=$WM_THIRD_PARTY_DIR/platforms/linux64Gcc/paraview-3.12.0 export PATH=$ParaView_DIR/bin:$PATH export PV_PLUGIN_PATH=$FOAM_LIBBIN/paraview-3.12 I got correct cmake path when I commanded which cmake until now, it looks everything's fine. I changed directory to $FOAM_UTILITIES/postProcessing/graphics/PV3Readers and typed command. wmSET ./Allwclean ./Allwmake 2>&1 | tee make.log.pv3foamreader I got Error as follows. + cd PV3blockMeshReader + mkdir -p Make/linux64GccDPOpt + cd Make/linux64GccDPOpt + cmake ../.. PV3blockMeshReader/Allwmake: line 13: cmake: command not found + make make: *** No targets specified and no makefile found. Stop. + PV3FoamReader/Allwmake So, I typed which cmake. Then, says /usr/bin/which: no cmake in (~~) I am comfused because it gave correct cmake PATH before I try to compile. I think it seems that environment configuration is broken. Why?? Any advice would help me to solve this problem. Thanks in advanced. smpark. |
January 9, 2012, 04:28 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings smpark,
Did you confirm that each variable is properly set? Code:
echo $Cmake_DIR And did you start a new terminal window/tab to make sure the environment was working as intended? Best regards, Bruno
January 9, 2012, 07:16 |
Sangmin Park
Rep Power: 15 |
Quickly answer..
Thanks, Bruno All environment variables are okay. Finally, I solved this problem an hour ago. The reason why environment configuration was broken is the wmSET command. wmSET command written on the official OpenFOAM web page makes environment configuration initial. Without wmSET command, I compiled ParaView and PV3FoamReader module. Best regards, smpark |
paraview 3.12, paraview plugin reader, pv3foamreader |
