Openfoam installation on beowulf cluster
Old   April 9, 2012, 02:33
Default Openfoam installation on beowulf cluster
lalupp
lalupp is on a distinguished road
Hi
We have a Beowulf cluster (32 cpus)
But we don't know how to install open foam in a cluster.
Is there step by step procedure to install the same
lalupp is offline   Reply With Quote
Old   April 9, 2012, 05:05
Retired Super Moderator
Bruno Santos
Greetings Lalupp,
To install on a cluster it's as simple as installing on the master machine and then rsync the folder to all of the nodes, or place the installation in a shared folder. The path to the OpenFOAM installation should be identical on all machines.
The more complicated detail is what OS and version are you using on your cluster?
Best regards,
Bruno
Old   April 9, 2012, 10:24
Default Openfoam install in a beowulf cluster
lalupp
Hi Bruno,
Thank to reply
I guess that this is the outline of procedure
My cluster oS ubuntu 11.04 with nfs share and openmpi
1) download tarball 2.10 (latest) and extract to a NFS shared folder
2) go to top-level source directory and execute the build script ./Allwmake. ( in master node)
3) Then I need to set necessary environment variables in each machine (nodes)
Right ?
Another query is that can we force the openfoam deb package to force to installl in any user directory rather than into the system folders (by default using synaptic)
[OpenFOAM.com] OpenFOAM 1.7.1 installation on LINUX UBUNTU 10.10 electrosin OpenFOAM Installation 40 May 31, 2016 05:11
OpenFOAM 1.7 installation on Redhat linux maxims OpenFOAM Installation 2 November 30, 2012 04:29
OpenFOAM Installation Meisam OpenFOAM Installation 6 January 31, 2012 15:43
OpenFoam 2.0.1 installation shailesh.nitk OpenFOAM Installation 4 October 4, 2011 08:50
Installation of OpenFOAM 1.7.1 to OprnSUSE 11.2 superfxfund OpenFOAM Installation 3 November 11, 2010 02:15
