[snappyHexMesh] Inlet/Outlet Faces are not meshed correctly
Old   November 23, 2015, 10:23
Default Inlet/Outlet Faces are not meshed correctly
Robert
RobertSoeldner is on a distinguished road
Dear FOAM'ler,
I have Problems with the snapping of my STL-Files. The measured Size of the Face from Catia isnt the same which i get from my OpenFOAM tool "inlet_average" (it shows me the size of the Face, the velocity components xyz & the pressure of the desired face).
The variations are:
measured face from Catia: 0,01385 mē
measured face from "inlet_average": 0,00747011 mē
On the pictures you can see that there are spots which arent meshed and connected. Does someone knows whats the reason for this problem?
Greetings
Robert
RobertSoeldner is offline   Reply With Quote
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 91 December 21, 2022 04:50
[snappyHexMesh] SHM Layer Addition Phase dickcruz OpenFOAM Meshing & Mesh Conversion 4 November 1, 2018 07:05
[Other] Mesh Importing Problem cuteapathy ANSYS Meshing & Geometry 2 June 24, 2017 05:29
Compressor Simulation using rhoPimpleDyMFoam Jetfire OpenFOAM Running, Solving & CFD 107 December 9, 2014 13:38
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
