[Gmsh] Gmsh physical line and .msh
Old   November 23, 2015, 05:10
Default Gmsh physical line and .msh
Chacha blabla
Chacha is on a distinguished road
Hi all,
I've got a problem with gmsh with this code
Point(1) = {-1, -0.8, 0, 0.3};
Point(2) = {0.3, -0.8, 0, 0.3};
Point(3) = {0.3, 0.3, 0, 0.3};
Point(4) = {-1, 0.3, 0, 0.3};
Line(1) = {1, 2};
Line(2) = {2, 3};
Line(3) = {3, 4};
Line(4) = {4, 1};
Line Loop(5) = {4, 1, 2, 3};
Plane Surface(6) = {5};
Physical Line("test")={4};
when the last line about the "Physical Line" is comment, the .msh contain all, but when it's not comment, the .msh is
$MeshFormat
2.2 0 8
$EndMeshFormat
$PhysicalNames
1
1 1 "test"
$EndPhysicalNames
$Nodes
5
1 -1 -0.8 0
2 -1 0.3 0
3 -1 0.02500000000071845 0
4 -1 -0.2499999999984228 0
5 -1 -0.5249999999991237 0
$EndNodes
$Elements
4
1 1 2 1 4 2 3
2 1 2 1 4 3 4
3 1 2 1 4 4 5
4 1 2 1 4 5 1
$EndElements
And does not containt the mesh...
Do you have an idea about that?
Thanks for your help!
Chacha is offline   Reply With Quote
Old   November 23, 2015, 08:10
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
And what is the problem (or should we call it difficulty?)? Gmsh did as you said to it: created 2D mesh and 1D physical group with name test.
alexeym is offline   Reply With Quote
Gmsh 4 compatibility with gmshToFoam gridley2 OpenFOAM Pre-Processing 1 January 14, 2019 13:06
[Gmsh] Nasa Nozzle: Plot 3D -->gmsh -->fluent - no physical groups Nico89 OpenFOAM Meshing & Mesh Conversion 1 June 14, 2016 05:40
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
[Gmsh] gmshToFoam problem: not the same mesh in Gmsh vs. paraview zhernadi OpenFOAM Meshing & Mesh Conversion 8 July 7, 2011 02:28
[Gmsh] Converting curved surfaces problem markdowlinguk OpenFOAM Meshing & Mesh Conversion 4 August 2, 2007 08:05
