[snappyHexMesh] Error snappyhexmesh - Multiple outside loops |
December 5, 2015, 09:37 |
#41 |
nasir musa yakubu
Rep Power: 12 |
Hello Bruno,
error still persist. i have run the mesh on of24x and followed your procedure. please have a look at the attached log file. https://www.dropbox.com/s/qpmypl0qfk...exMesh.gz?dl=0 thanks nas |
December 6, 2015, 15:38 |
#42 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi Nasir,
I've finally managed to take a look at the latest log file. Unfortunately I completely forgot that when we are running in parallel, we need to use "Pout" instead of "Info" What happened is that in the log file you got, it only showed the output for the master process and it did not show the output for the slave process that crashed, which means that this way I can't see what really happened Please follow these steps to update the source code and respective build: Code:
foam git pull wyldckat MultiOLoops wmake libso src/dynamicMesh Best regards, Bruno |
December 7, 2015, 14:30 |
#43 |
nasir musa yakubu
Rep Power: 12 |
Hello Bruno,
i have updated your source code and heres the output of the log file. https://www.dropbox.com/s/qpmypl0qfk...exMesh.gz?dl=0 Also, i don't understand what you mean by pout and info, am i meant to modify Code:
mpirun -np 16 snappyHexMesh -overwrite -parallel > log.snappyHexMesh 2>&1 kind regards |
December 7, 2015, 20:27 |
#44 |
Rep Power: 24 |
Guess what guys! Now I have a case that has this same error!
Later this week I can download the code and try it out.. |
December 8, 2015, 05:07 |
#45 | |
Bruno Santos
Rep Power: 128 |
Hi Nasir and me3840,
In the modified code I provided for OpenFOAM 2.4.x, I first used this code: Code:
Info << "cellI: " << cellI << "\tcEdges: " << cEdges << nl << "\tfaceRegion: " << faceRegion << endl; Code:
faceRegion: 0 ( ) cellI: 23286 cEdges: 12 ( 651273 651275 651276 2077722 2077724 914463 541238 541242 541243 2088025 2088026 893919 ) When I changed the code to this: Code:
Pout << "cellI: " << cellI << "\tcEdges: " << cEdges << nl << "\tfaceRegion: " << faceRegion << endl; Code:
[3] cellI: 524837 cEdges: [3] 12 [3] ( [3] 268946 [3] 262171 [3] 262172 [3] 262173 [3] 265001 [3] 265002 [3] 267699 [3] 267700 [3] 284912 [3] 284913 [3] 287602 [3] 284915 [3] ) [3] [3] faceRegion: [3] 2 [3] ( [3] 1897870 0 [3] 1898007 0 [3] ) [1] cellI: 529679 cEdges: [1] 12 [1] ( [1] 1812109 [1] 1373846 [1] 1373848 [1] 1373850 [1] 1803296 [1] 1803298 [1] 1814983 [1] 1453931 [1] 1453932 [1] 1453937 [1] 1453938 [1] 1470710 [1] ) [1] [1] faceRegion: [1] 0 [1] ( [1] ) How many cells does your mesh need before crashing? If it's lesser than 4-5 million cells, I can test with your case. Best regards, Bruno |
December 8, 2015, 05:53 |
#46 |
Bruno Santos
Rep Power: 128 |
I'm doing a separate post, since this is going to be a big long.
I've diagnosed part of the problem. In Nasir's latest log, there were 4 processes out of 16 that crashed with similar errors, not just one, therefore there are at least 4 sections of the mesh that share a common problem. If we look at the output for process #15: Code:
[15] cellI: 268506 cEdges: [15] 12 [15] ( [15] 1323428 [15] 1323429 [15] 1913565 [15] 1907422 [15] 275562 [15] 275563 [15] 275564 [15] 275568 [15] 275569 [15] 1323637 [15] 275573 [15] 275574 [15] ) [15] [15] faceRegion: [15] 6 [15] ( [15] 1500378 0 [15] 1500379 0 [15] 1500389 0 [15] 1500133 0 [15] 1500134 0 [15] 1500135 0 [15] ) [15] bigFace: [15] 6 [15] ( [15] 4(682636 416857 86432 86433) [15] 4(679566 86435 416930 682579) [15] 4(679566 682579 682636 86433) [15] 4(416930 86435 86432 416857) [15] 4(416930 416857 682636 682579) [15] 4(679566 86433 86432 86435) [15] ) [15] [15] bigFace.edgeLoops(): 0() [15] regionToFaces: [15] 1 [15] ( [15] 0 6(1500378 1500379 1500389 1500133 1500134 1500135) [15] ) [15] [15] [15] [15] --> FOAM FATAL ERROR: [15] Multiple outside loops:0() [15] [15] From function combineFaces::getOutsideFace(const indirectPrimitivePatch&) [15] in file polyTopoChange/polyTopoChange/combineFaces.C at line 435. Code:
[15] bigFace: [15] 6 [15] ( [15] 4(682636 416857 86432 86433) [15] 4(679566 86435 416930 682579) [15] 4(679566 682579 682636 86433) [15] 4(416930 86435 86432 416857) [15] 4(416930 416857 682636 682579) [15] 4(679566 86433 86432 86435) [15] ) But in this case, all points of the list "bigFace" are repeated 3 times, which means that all 6 faces are associated to the same STL solid, which means that the cell is fully closed by the same surface, resulting in that there is no outside edge. In other words, the cell is like a sphere with a single face and no edges. Now, the problem is to decide what snappyHexMesh should do in such a scenario... The problem seems to be in the method "combineFaces::faceNeighboursValid", which is possibly incorrectly assessing that the face neighbours are valid... I'll update this post when I can figure it out or have any more news on this. edit: Sorry, but I didn't manage to study this issue better the rest of the day. I've added this to my to-do list, which I will possibly only be able to look into in the upcoming weekend Last edited by wyldckat; December 8, 2015 at 16:06. Reason: see "edit:" |
December 9, 2015, 06:11 |
#47 |
nasir musa yakubu
Rep Power: 12 |
Hello Bruno,
Thanks for your reply. yes i believe you are right, the way snappyhexmesh handles the meshing process might not be well suited for this application. however, i have tried a slightly different mesh design, by ramping up my base mesh grid refinement to something like this: Code:
blocks ( hex (0 1 2 3 4 5 6 7) (200 150 200) simpleGrading (1 1 1) ); Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 3.0.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object snappyHexMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Which of the steps to run castellatedMesh true; snap false; addLayers false; // Geometry. Definition of all surfaces. All surfaces are of class // searchableSurface. // Surfaces are used // - to specify refinement for any mesh cell intersecting it // - to specify refinement for any mesh cell inside/outside/near // - to 'snap' the mesh boundary to the surface geometry { . . . // Settings for the castellatedMesh generation. castellatedMeshControls { // Refinement parameters // ~~~~~~~~~~~~~~~~~~~~~ // If local number of cells is >= maxLocalCells on any processor // switches from from refinement followed by balancing // (current method) to (weighted) balancing before refinement. maxLocalCells 20000000; // Overall cell limit (approximately). Refinement will stop immediately // upon reaching this number so a refinement level might not complete. // Note that this is the number of cells before removing the part which // is not 'visible' from the keepPoint. The final number of cells might // actually be a lot less. maxGlobalCells 160000000; // The surface refinement loop might spend lots of iterations // refining just a few cells. This setting will cause refinement // to stop if <= minimumRefine are selected for refinement. Note: // it will at least do one iteration (unless the number of cells // to refine is 0) minRefinementCells 0; // Number of buffer layers between different levels. // 1 means normal 2:1 refinement restriction, larger means slower // refinement. nCellsBetweenLevels 10; // Explicit feature edge refinement // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ // Specifies a level for any cell intersected by its edges. // This is a featureEdgeMesh, read from constant/triSurface for now. features ( { file "inlet.eMesh"; level 1; } { file "outlet.eMesh"; level 1; } { file "lens.eMesh"; levels ((0.0003 0)); } { file "insulator.eMesh"; levels ((0.0003 0)); } { file "s1.eMesh"; levels ((0.00001 1) (0.00002 0)); } { file "s2.eMesh"; levels ((0.00001 1) (0.00002 0)); } { file "s3.eMesh"; levels ((0.00001 1) (0.00002 0)); } { file "s4.eMesh"; levels ((0.00001 1) (0.00002 0)); } { file "s5.eMesh"; levels ((0.00001 1) (0.00002 0)); } { file "s6.eMesh"; levels ((0.00001 1) (0.00002 0)); } { file "s7.eMesh"; levels ((0.00001 1) (0.00002 0)); } { file "s8.eMesh"; levels ((0.00001 1) (0.00002 0)); } { file "s9.eMesh"; levels ((0.00001 1) (0.00002 0)); } { file "s10.eMesh"; levels ((0.00001 1) (0.00002 0)); } { file "s11.eMesh"; levels ((0.00001 1) (0.00002 0)); } { file "s12.eMesh"; levels ((0.00001 1) (0.00002 0)); } { file "s13.eMesh"; levels ((0.00001 1) (0.00002 0)); } { file "s14.eMesh"; levels ((0.00001 1) (0.00002 0)); } { file "s15.eMesh"; levels ((0.00001 1) (0.00002 0)); } ); // Surface based refinement // ~~~~~~~~~~~~~~~~~~~~~~~~ // Specifies two levels for every surface. The first is the minimum level, // every cell intersecting a surface gets refined up to the minimum level. // The second level is the maximum level. Cells that 'see' multiple // intersections where the intersections make an // angle > resolveFeatureAngle get refined up to the maximum level. refinementSurfaces { inlet { // Surface-wise min and max refinement level level (0 1); faceZone inlet; cellZone inlet; zoneInside true; } outlet { // Surface-wise min and max refinement level level (0 3); faceZone outlet; cellZone outlet; zoneInside true; } lens { // Surface-wise min and max refinement level level (0 3); faceZone lens; cellZone lens; zoneInside true; } insulator { // Surface-wise min and max refinement level level (0 3); faceZone insulator; cellZone insulator; zoneInside true; } s1 { // Surface-wise min and max refinement level level (0 3); faceZone s1; cellZone s1; zoneInside true; } s2 { // Surface-wise min and max refinement level level (0 3); faceZone s2; cellZone s2; zoneInside true; } s3 { // Surface-wise min and max refinement level level (0 3); faceZone s3; cellZone s3; zoneInside true; } s4 { // Surface-wise min and max refinement level level (0 3); faceZone s4; cellZone s4; zoneInside true; } s5 { // Surface-wise min and max refinement level level (0 3); faceZone s5; cellZone s5; zoneInside true; } s6 { // Surface-wise min and max refinement level level (0 3); faceZone s6; cellZone s6; zoneInside true; } s7 { // Surface-wise min and max refinement level level (0 3); faceZone s7; cellZone s7; zoneInside true; } s8 { // Surface-wise min and max refinement level level (0 3); faceZone s8; faceType boundary; cellZone s8; zoneInside true; } s9 { // Surface-wise min and max refinement level level (0 3); faceZone s9; cellZone s9; zoneInside true; } s10 { // Surface-wise min and max refinement level level (0 3); faceZone s10; cellZone s10; zoneInside true; } s11 { // Surface-wise min and max refinement level level (0 3); faceZone s11; cellZone s11; zoneInside true; } s12 { // Surface-wise min and max refinement level level (0 3); faceZone s12; faceType boundary; cellZone s12; zoneInside true; } s13 { // Surface-wise min and max refinement level level (0 3); faceZone s13; faceType boundary; cellZone s13; zoneInside true; } s14 { // Surface-wise min and max refinement level level (0 3); faceZone s14; faceType boundary; cellZone s14; zoneInside true; } s15 { // Surface-wise min and max refinement level level (0 3); faceZone s15; faceType boundary; cellZone s15; zoneInside true; } } // Resolve sharp angles resolveFeatureAngle 180; // Region-wise refinement // ~~~~~~~~~~~~~~~~~~~~~~ // Specifies refinement level for cells in relation to a surface. One of // three modes // - distance. 'levels' specifies per distance to the surface the // wanted refinement level. The distances need to be specified in // descending order. // - inside. 'levels' is only one entry and only the level is used. All // cells inside the surface get refined up to the level. The surface // needs to be closed for this to be possible. // - outside. Same but cells outside. refinementRegions { inlet { mode inside; levels ((1E15 9)); } outlet { mode inside; levels ((1E15 9)); } lens { mode distance; levels ((0.001 1) (0.002 0)); } insulator { mode distance; levels ((0.001 1) (0.002 0)); } s1 { mode distance; levels ((0.00001 1) (0.00002 0)); } s2 { mode distance; levels ((0.00001 1) (0.00002 0)); } s3 { mode distance; levels ((0.00001 1) (0.00002 0)); } s4 { mode distance; levels ((0.00001 1) (0.00002 0)); } s5 { mode distance; levels ((0.00001 1) (0.00002 0)); } s6 { mode distance; levels ((0.00001 1) (0.00002 0)); } s7 { mode distance; levels ((0.00001 1) (0.00002 0)); } s8 { mode distance; levels ((0.00001 1) (0.00002 0)); } s9 { mode distance; levels ((0.00001 1) (0.00002 0)); } s10 { mode distance; levels ((0.00001 1) (0.00002 0)); } s11 { mode distance; levels ((0.00001 1) (0.00002 0)); } s12 { mode distance; levels ((0.00001 1) (0.00002 0)); } s13 { mode distance; levels ((0.00001 1) (0.00002 0)); } s14 { mode distance; levels ((0.00001 1) (0.00002 0)); } s15 { mode distance; levels ((0.00001 1) (0.00002 0)); } } // Mesh selection // ~~~~~~~~~~~~~~ // After refinement patches get added for all refinementSurfaces and // all cells intersecting the surfaces get put into these patches. The // section reachable from the locationInMesh is kept. // NOTE: This point should never be on a face, always inside a cell, even // after refinement. locationInMesh (0.0723594 0.0944272 0.0745); // Whether any faceZones (as specified in the refinementSurfaces) // are only on the boundary of corresponding cellZones or also allow // free-standing zone faces. Not used if there are no faceZones. allowFreeStandingZoneFaces false; } // Settings for the snapping. snapControls { //- Number of patch smoothing iterations before finding correspondence // to surface nSmoothPatch 5; //was 3 //- Relative distance for points to be attracted by surface feature point // or edge. True distance is this factor times local // maximum edge length. tolerance 5; //was 5 //- Number of mesh displacement relaxation iterations. nSolveIter 30; //- Maximum number of snapping relaxation iterations. Should stop // before upon reaching a correct mesh. nRelaxIter 5; //was 5 //- Highly experimental and wip: number of feature edge snapping // iterations. Leave out altogether to disable. // Of limited use in this case since faceZone faces not handled. nFeatureSnapIter 10; // was 10 // New settings from openfoam 2.2 onwards for SHMesh implicitFeatureSnap false; // default is false - detects without doing surfaceFeatureExtract explicitFeatureSnap true; // default is true multiRegionFeatureSnap false; // deafault is false - detects features between multiple surfaces } // Settings for the layer addition. addLayersControls { relativeSizes true; // Per final patch (so not geometry!) the layer information layers { s1 {nSurfaceLayers 1;} // was 3 s2 {nSurfaceLayers 1;} // was 3 s3 {nSurfaceLayers 1;} // was 3 s4 {nSurfaceLayers 1;} // was 3 s5 {nSurfaceLayers 1;} // was 3 s6 {nSurfaceLayers 1;} // was 3 s7 {nSurfaceLayers 1;} // was 3 s8 {nSurfaceLayers 1;} // was 3 s9 {nSurfaceLayers 1;} // was 3 s10 {nSurfaceLayers 1;} // was 3 s11 {nSurfaceLayers 1;} // was 3 s12 {nSurfaceLayers 1;} // was 3 s13 {nSurfaceLayers 1;} // was 3 s14 {nSurfaceLayers 1;} // was 3 s15 {nSurfaceLayers 1;} // was 3 } // Expansion factor for layer mesh expansionRatio 1; //was 1.3 // Wanted thickness of final added cell layer. If multiple layers // is the thickness of the layer furthest away from the wall. // Relative to undistorted size of cell outside layer. // See relativeSizes parameter. finalLayerThickness 0.000025; //was 0 // Minimum thickness of cell layer. If for any reason layer // cannot be above minThickness do not add layer. // Relative to undistorted size of cell outside layer. minThickness 0.000015; //was 0.1 // If points get not extruded do nGrow layers of connected faces that are // also not grown. This helps convergence of the layer addition process // close to features. // Note: changed(corrected) w.r.t 17x! (didn't do anything in 17x) nGrow 0; // Advanced settings // When not to extrude surface. 0 is flat surface, 90 is when two faces // are perpendicular featureAngle 180; // Maximum number of snapping relaxation iterations. Should stop // before upon reaching a correct mesh. nRelaxIter 6; //was 3 // Number of smoothing iterations of surface normals nSmoothSurfaceNormals 5; //was 1 // Number of smoothing iterations of interior mesh movement direction nSmoothNormals 3; //was 3 // Smooth layer thickness over surface patches nSmoothThickness 5; //was 2 // Stop layer growth on highly warped cells maxFaceThicknessRatio 0.5; // Reduce layer growth where ratio thickness to medial // distance is large maxThicknessToMedialRatio 0.03; //was 1 // Angle used to pick up medial axis points // Note: changed(corrected) w.r.t 17x! 90 degrees corresponds to 130 in 17x. minMedianAxisAngle 90; // Create buffer region for new layer terminations nBufferCellsNoExtrude 0; // Overall max number of layer addition iterations. The mesher will exit // if it reaches this number of iterations; possibly with an illegal // mesh. nLayerIter 50; } // Generic mesh quality settings. At any undoable phase these determine // where to undo. meshQualityControls { maxNonOrtho 180; //was 95 maxBoundarySkewness 1; //was 20 maxInternalSkewness 1; //was 4 maxConcave 180; //was 80 minFlatness 0.5; //was 0.5 minVol 1e-15; //was 1e-15 minTetQuality 1e-15; // was 1e-15 minArea -1; minTwist 0.002; //was 0.002 minDeterminant 0.001; //was 0.001 minFaceWeight 0.001; //was 0.001 minVolRatio 0.0000000000000001; // was 0.01 minTriangleTwist -1; // Advanced nSmoothScale 10; //was 4 errorReduction 1; // was 0.75 } // Advanced // Merge tolerance. Is fraction of overall bounding box of initial mesh. // Note: the write tolerance needs to be higher than this. mergeTolerance 1e-7; //was 1e-6 // ************************************************************************* // so now i need to figure out a way to increase my my base mesh grid level to something like : Code:
blocks ( hex (0 1 2 3 4 5 6 7) (800 800 800) simpleGrading (1 1 1) ); kind regards Nas |
December 9, 2015, 17:52 |
#48 |
Bruno Santos
Rep Power: 128 |
Quick answers:
December 16, 2015, 16:05 |
#49 |
nasir musa yakubu
Rep Power: 12 |
Hello Bruno,
i have decided to give salome to openFoam option a trial and encountered a little problem, o am wondering if you can give me any advice on how to tackle the problem. http://www.cfd-online.com/Forums/ope...tml#post577812 thanks Nas |
March 6, 2016, 09:48 |
#50 | |
Bruno Santos
Rep Power: 128 |
Greetings to all!
For future reference, on this topic: Quote:
Best regards, Bruno
March 7, 2016, 02:35 |
#51 |
nasir musa yakubu
Rep Power: 12 |
Hello Bruno,
we can definitely continue hunting down the bug once i am done with my work. i still have all my snappy hex cases. kind regards nas |
February 3, 2018, 07:37 |
#52 |
Aaditya Maharashtra
Rep Power: 8 |
Solved!
I thought this problem arises when featureEdges of two different objects coincide with each other |
November 12, 2018, 16:16 |
#53 | |
Ed O'Malley
Rep Power: 8 |
I know this is an old topic, but it came up for me today with OpenFOAM6. I tried many ways to solve the problem in the SHMDict file, but ultimately, just providing slightly reduced tolerance for the Deviation and Angle when crating my .stl file in SolidWorks fixed the problem. Hope this helps someone else! |
March 8, 2019, 09:42 |
resolveFeatureAngle
#54 |
Josh Williams
Rep Power: 7 |
Old problem but hope my solution will provide an alternative for someone who has this problem in the future. I had the same error message and my
resolveFeatureAngle = 175; When it should've been resolveFeatureAngle = 30; |
solidDisplacementFoam vs. solidEquilibriumDisplacementFoam | Tobi | OpenFOAM Running, Solving & CFD | 6 | September 23, 2021 03:26 |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[snappyHexMesh] Multiple outside loops error | badoumba | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2019 07:52 |
[OpenFOAM.org] Install openFOAM 3.0.1 in Ubuntu 16.04 LTS from Deb packs | Pier84 | OpenFOAM Installation | 4 | June 18, 2016 16:22 |
OpenFOAM static build on Cray XT5 | asaijo | OpenFOAM Installation | 9 | April 6, 2011 12:21 |
