[snappyHexMesh] Using snappyHexMesh to create a multi-region mesh for a whole building |
April 24, 2014, 16:06 |
Lucas Mutti
Hello guys,
I am having a problem that I do not know how to solve. On the big picture I have a house modeled in Solidworks and I am trying to perform a conjugate heat transfer analysis on it. I have followed the multiRegion snappy tutorial but I still cannot get it to work. For both trials, I have concatenated internal and external surfaces into two stls. The first trial deals with two stls that are not closed; therefore, it doesn't surprise me that it doesn't snap both inside and outside simultaneously. Yet, the second trial deals with closed stls and still I end up not getting a desirable result. In fact, both trials give me the same end result. The outside wall mesh looks fine however once I get inside the geometry I cannot see the mesh of the internal wall. Please note that this is a very coarse mesh on blockMeshDict (40 40 40) in order to speed up snappy's output. Also please find attached the sample for closed stl files. I would greatly appreciate if you guys could take a look since I have been stuck in this problem for more than a week. I am trying to get this working so I can proceed with my simulation and submit my thesis. Please let me know if you are able to download in Dropbox. https://www.dropbox.com/s/g0u22x3hqy...ntativaOne.zip Cheers! |
[Other] conformed FSI mesh for unstructured fluid region | ashish.svm | OpenFOAM Meshing & Mesh Conversion | 10 | August 2, 2019 08:40 |
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell | Arman_N | OpenFOAM Meshing & Mesh Conversion | 1 | May 20, 2019 17:16 |
OpenFoam "Permission denied" and "command not found" problems. | iyidaniel@yahoo.co.uk | OpenFOAM Running, Solving & CFD | 11 | January 2, 2018 06:47 |
[blockMesh] Include list of points | Hikachu | OpenFOAM Meshing & Mesh Conversion | 0 | June 20, 2011 09:03 |
Compilation error OF1.5-dev on Suse10.3 | darenyang | OpenFOAM Installation | 0 | April 29, 2009 04:55 |
