[snappyHexMesh] SHM not defining faces
Old   January 8, 2016, 04:55
Default SHM not defining faces
Gareth
bullmut is on a distinguished road
Hi All
I have spent some time looking through the propeller tut. It works on my system and was thus the base for my own work.
I am trying to simulate a VAWT in 2D with a cylindrical AMI patch and using pimpleDyFoam. I have followed the same steps as the tutorial, and most of the dictionaries are the same. having stepped through the procedure and tweaked files accordingly i am still unable to get my mesh working.
The case: I have 3 blades in stl format that are not fully closed surfaces. They extend past the boundary of a simple block i define in blockMesh (this has worked before when making meshes).
Run blockMesh - done
Run surfaceFetureExtract - done
Run snappyHexMesh - done ...
I then check my boundary file and it states i have a new patch, in this instance called "rotate" but it has 0 faces...
Continuing on i run createPatch - done. AMI1 and 2 are created from the rotate and rotate_slave patches.
My snappyHexMeshDict is almost identical to the propeller case version. Can anyone please tell me why i have no faces on the rotate patch?
I am attaching the SHM dict and log as well as the script used to run the process and the boundary file from my constant/polymesh folder
Thanks people
bullmut is offline   Reply With Quote
ami, propeller, shm
Decomposing meshes Tobi OpenFOAM Pre-Processing 22 February 24, 2023 09:23
[Other] Mesh Importing Problem cuteapathy ANSYS Meshing & Geometry 2 June 24, 2017 05:29
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 03:21
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
[Gmsh] Vertex numbering is dense KateEisenhower OpenFOAM Meshing & Mesh Conversion 7 August 3, 2015 10:49
