[snappyHexMesh] Problem with the boundary layer using snappyHexMesh |
January 18, 2010, 07:22 |
Andre Z
this is my first post here. Currently I am working at a company which provides CFD services mainly for the automotive industry. Right now I am still an intern but shortly will start writing my diploma thesis here. Well my task is to find out what can be done with OpenFoam. Often, when I try to create a mesh with snappyHexMesh I get problems with the boundary layer. And this leads to my first question: Check out the attached picture of a Porsche I have meshed. Why is the boundary layer below the door? In case you think my blockMeshDict is fault, here is the text: Code:
FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1.0; vertices ( ( -70 -70 8.000) ( 300 -70 8.000) ( 300 140 8.000) ( -70 140 8.000) ( -70 -70 100.000) ( 300 -70 100.000) ( 300 140 100.000) ( -70 140 100.000) ); blocks ( hex (0 1 2 3 4 5 6 7) (40 20 10) simpleGrading (1 1 1) ); edges ( ); patches ( patch inlet ( (0 4 7 3) ) patch outlet ( (1 2 6 5) ) patch floor ( (0 3 2 1) ) patch sides ( (0 1 5 4) (4 5 6 7) (2 3 7 6) ) ); mergeMatchPairs ( ); Last edited by LVDH; January 18, 2010 at 07:39. |
snappyhexmesh |
[snappyHexMesh] Triangular elements in boundary layers generated by snappyHexMesh | mike.franky | OpenFOAM Meshing & Mesh Conversion | 0 | June 3, 2018 09:46 |
[cfMesh] boundary layer problem using cfMesh | dupeng | OpenFOAM Community Contributions | 1 | May 28, 2018 15:30 |
[snappyHexMesh] problem with snappyHexMesh | kanes | OpenFOAM Meshing & Mesh Conversion | 10 | January 26, 2016 06:11 |
Validity & transformation of boundary layer equations | Obad | Main CFD Forum | 2 | April 27, 2015 02:59 |
[snappyHexMesh] Problem with snappyHexMesh | samiam1000 | OpenFOAM Meshing & Mesh Conversion | 2 | December 13, 2012 08:41 |
