[snappyHexMesh] Problem with the boundary layer using snappyHexMesh
Like Tree1Likes
  • 1 Post By openfoam_user
Old   January 18, 2010, 07:22
Default Problem with the boundary layer using snappyHexMesh
LVDH's Avatar
Andre Z
LVDH is on a distinguished road
this is my first post here.
Currently I am working at a company which provides CFD services mainly for the automotive industry. Right now I am still an intern but shortly will start writing my diploma thesis here. Well my task is to find out what can be done with OpenFoam.
Often, when I try to create a mesh with snappyHexMesh I get problems with the boundary layer. And this leads to my first question:
Check out the attached picture of a Porsche I have meshed.
Why is the boundary layer below the door?
In case you think my blockMeshDict is fault, here is the text:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 1.0;
vertices
      (       -70        -70        8.000)
      (        300        -70        8.000)
      (        300         140        8.000)
      (       -70         140        8.000)
      (       -70        -70        100.000)
      (        300        -70        100.000)
      (        300         140        100.000)
      (       -70         140        100.000)
blocks
      hex (0 1 2 3 4 5 6 7) (40 20 10) simpleGrading (1 1 1)
edges
patches
      patch inlet
            (0 4 7 3)
      patch outlet
            (1 2 6 5)
      patch floor
            (0 3 2 1)
      patch sides
            (0 1 5 4)
            (4 5 6 7)
            (2 3 7 6)
mergeMatchPairs
LVDH is offline   Reply With Quote
Old   January 19, 2010, 00:17
amgode's Avatar
Amol
amgode is on a distinguished road
You need to post the snappyHexMeshDict ........
-- Amol
amgode is offline   Reply With Quote
Old   January 19, 2010, 05:07
LVDH's Avatar
Andre Z
I seem to have solved my first problem. The surrounding box generated by blockMesh cut off a small part of the cars tires. I did this on purpose but enlarging the box and therefor having a levitating car got the boundary layer on the car.
Still I have a problem with this boundary layer. It is not to be found everywhere. On some sections it is missing on some others it does not have the desired number of layers. See the attached pictures.
Since I have rescaled the 100m long Porsche to a 4m long Porsche my Dicts have changed:
     version     2.0;
     format      ascii;
     class       dictionary;
 vertices
       (       -3        -3        0.25)
       (        12        -3        0.25)
       (        12         6        0.25)
       (       -3         6        0.25)
       (       -3        -3        4.000)
       (        12        -3        4.000)
       (        12         6        4.000)
       (       -3         6        4.000)
 /*      (       -70        -70        6.000)
       (        300        -70        6.000)
       (        300         140        6.000)
       (       -70         140        6.000)
       (       -70        -70        100.000)
       (        300        -70        100.000)
       (        300         140        100.000)
       (       -70         140        100.000)*/
 blocks
 edges
 patches
       patch inlet
             (0 4 7 3)
       patch outlet
             (1 2 6 5)
       patch floor
             (0 3 2 1)
       patch sides
             (0 1 5 4)
             (4 5 6 7)
             (2 3 7 6)
 mergeMatchPairs
     version     2.0;
     format      ascii;
     class       dictionary;
     object      snappyHexMeshDict;
 castellatedMesh true;
 snap            true;
 addLayers       true;
 geometry
     porsche.stl
         type triSurfaceMesh;
         name AUTO;
     refinementBox
         type searchableBox;
         min (-1 -0.5 0.25);
         max ( 8  3.5 3);
 castellatedMeshControls
     maxLocalCells 100000;
     maxGlobalCells 200000;
     minRefinementCells 10;
     nCellsBetweenLevels 6;
     features
         //    file "someLine.eMesh";
         //    level 2;
     refinementSurfaces
         AUTO
             level (4 4);
     resolveFeatureAngle 30;
     refinementRegions
         refinementBox
             mode inside;
             levels ((1E15 2));
       AUTO
         mode distance;
         levels ((0.6 3) (1.1 2));
     locationInMesh (-2.234 -2.0343 3.43);
 snapControls
     nSmoothPatch 4;
     tolerance 4.5;
     nSolveIter 40;
     nRelaxIter 6;
 addLayersControls
     relativeSizes true;
     layers
         AUTO_patch8224
             nSurfaceLayers 5;
     expansionRatio 1.2;
     finalLayerThickness 0.2;
     minThickness 0.04;
     nGrow 1;
     featureAngle 30;
     nRelaxIter 3;
     nSmoothSurfaceNormals 1;
     nSmoothNormals 3;
     nSmoothThickness 10;
     maxFaceThicknessRatio 0.5;
     maxThicknessToMedialRatio 0.3;
     minMedianAxisAngle 130;
     nBufferCellsNoExtrude 0;
     nLayerIter 50;
 meshQualityControls
     maxNonOrtho 65;
     maxBoundarySkewness 20;
     maxInternalSkewness 4;
     maxConcave 80;
     minFlatness 0.5;
     minVol 1e-13;
     minArea -1;
     minTwist 0.02;
     minDeterminant 0.001;
     minFaceWeight 0.02;
     minVolRatio 0.01;
     minTriangleTwist -1;
     nSmoothScale 4;
     errorReduction 0.75;
  debug 0;
 mergeTolerance 1E-6;
Old   January 26, 2010, 23:58
amgode's Avatar
Amol
Check the post below and see if it helps!
http://www.cfd-online.com/Forums/ope...modelling.html
Old   January 28, 2010, 07:36
LVDH's Avatar
Andre Z
I have tried the tips deducted from that thread.
Now the mesh is getting better. Still there are areas without boundarylayer.
I guess I just have to tweak the snappyHexMesh settings a little more.
I never had such trouble, but I guess after I finish this mesh my new experience will allow me to get my other stuff meshed a bit faster.
Hey, maybe someone else who tried to mesh this car (I have seen a few other meshes) can show me his snappyDict?
Old   March 4, 2010, 07:11
stephane sanchi
openfoam_user is on a distinguished road
Hi Andre,
I have exactly the same problem. I have areas where there is no boundary layers.
Did you solve the problem ?
Which parameters are important to improve the boundary layers ?
Best regards,
Stephane.
openfoam_user is offline   Reply With Quote
Old   March 4, 2010, 08:45
stephane sanchi
I have attached a picture to show again the problem.
There are some areas (corners) where there is no layer.
Stephane.
Old   March 10, 2010, 08:46
stephane sanchi
Any ideas how to solve this problem ?
Stephane.
Old   March 15, 2010, 07:47
Julius
juliuslein is on a distinguished road
Hello Stephane,
all snappyHexMesh boundary layers were collapsing at the end of a surface, this seems to be normal. Have look at the Porsche above, too. This should be modifyable in a certain range with the featureAngle setting in the "addLayerControls" subdictionary.
Good Luck, Julius
juliuslein is offline   Reply With Quote
Old   March 15, 2010, 08:30
stephane sanchi
Hi Julius,
it seems to work (see attached picture).
I have changed the featureAngle value in the "addLayerControls" subdictionary.
Default value was 30
New value is 5
To be sure I would like to select only the cells located into the boundary layers. Do you know how to do it with paraview ?
Regards,
Stephane.
Richal Sun likes this.
Old   March 15, 2010, 09:19
Julius
Hello again,
if you're using ParaFoam (paraview with the native OpenFOAM reader) you should be able to select the "include Sets" option. Now the "added Cells - cellSet" and the "layerFaces - faceSet" appear in the "region status" box. The added Cells set should be what you're looking for.
Regards, Julius
Old   March 15, 2010, 09:42
stephane sanchi
Julius,
I can't find the "region status" box !
Stephane.
Old   March 15, 2010, 10:30
Julius
Stephane,
If you use paraFoam it will look like the following screenshot. There you see the mentioned box and above the "include sets" option checked.
In case you don't know how to use / compile paraFoam and the necessary PV3FoamReader please search the forum because this is a common issue.
Regards, Julius
Old   March 15, 2010, 10:42
stephane sanchi
Julius,
OK. Thanks. Now I can visualize the boundary layers cells.
I use paraFoam 3.6.1. And the box name is mesh parts.
Regards,
Stephane.
snappyhexmesh
[snappyHexMesh] Triangular elements in boundary layers generated by snappyHexMesh mike.franky OpenFOAM Meshing & Mesh Conversion 0 June 3, 2018 09:46
[cfMesh] boundary layer problem using cfMesh dupeng OpenFOAM Community Contributions 1 May 28, 2018 15:30
[snappyHexMesh] problem with snappyHexMesh kanes OpenFOAM Meshing & Mesh Conversion 10 January 26, 2016 06:11
Validity & transformation of boundary layer equations Obad Main CFD Forum 2 April 27, 2015 02:59
[snappyHexMesh] Problem with snappyHexMesh samiam1000 OpenFOAM Meshing & Mesh Conversion 2 December 13, 2012 08:41
