[blockMesh] Substitution of y with z in number of cell - definition of blocks
Old   March 15, 2010, 15:46
Question Substitution of y with z in number of cell - definition of blocks
Marco
om3ro is on a distinguished road
I don't understand why the number of cells in the y and z directions is inverted when running the following code. I can see in paraFoam that in order to obtain the 2D case I must invert the y with z coordinate:
blocks
hex (1 7 6 0 3 9 8 2) (20 1 10) simpleGrading (1 1 1)
instead of
blocks
hex (1 7 6 0 3 9 8 2) (20 10 1) simpleGrading (1 1 1)
This is my constant/polyMesh/blockMeshDict:
| \\ / O peration | Version: 1.6 |
| \\ / A nd | Web: http://www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 0.001;
vertices
(-0.8 -3.43 -0.8) // 0
(-0.8 -3.43 0) // 1
(-0.8 -0.38 -0.8) // 2
(-0.8 -0.38 0) // 3
(-0.8 0 -0.8) // 4
(-0.8 0 0) // 5
(0 -3.43 -0.8) // 6
(0 -3.43 0) // 7
(0 -0.38 -0.8) // 8
(0 -0.38 0) // 9
(0 0 -0.8) // 10
(0 0 0) // 11
(0.01 -3.43 -0.8) // 12
(0.01 -3.43 0) // 13
(0.01 -0.38 -0.8) // 14
(0.01 -0.38 0) // 15
(0.01 0 -0.8) // 16
(0.01 0 0) // 17
(0.8 -3.43 -0.8) // 18
(0.8 -3.43 0) // 19
(0.8 -0.38 -0.8) // 20
(0.8 -0.38 0) // 21
(0.8 0 -0.8) // 22
(0.8 0 0) // 23
blocks
hex (3 9 8 2 5 11 10 4) (20 10 1) simpleGrading (1 1 1)
hex (9 15 14 8 11 17 16 10) (5 10 1) simpleGrading (1 1 1)
hex (13 19 18 12 15 21 20 14) (20 10 1) simpleGrading (1 1 1)
hex (15 21 20 14 17 23 22 16) (20 10 1) simpleGrading (1 1 1)
edges
patches
patch inlet
(3 2 0 1)
(5 4 2 3)
patch outlet
(19 18 20 21)
(21 20 22 23)
wall upperWall
(5 11 10 4)
(11 17 16 10)
(17 23 22 16)
wall lowerWall
(1 0 6 7)
(6 8 9 7)
(9 8 14 15)
(13 15 14 12)
(13 12 18 19)
empty frontAndBack
(7 9 3 1)
(9 11 5 3)
(15 17 11 9)
(19 21 15 13)
(21 23 17 15)
(0 2 8 6)
(2 4 10 8)
(8 10 16 14)
(12 14 20 18)
(14 16 22 20)
mergePatchPairs
Here come 0/p and 0/U:
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
inlet
type zeroGradient;
outlet
type fixedValue;
value uniform 0;
upperWall
type zeroGradient;
lowerWall
type zeroGradient;
frontAndBack
type empty;
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
inlet
type fixedValue;
value uniform (0.01 0 0);
outlet
type zeroGradient;
upperWall
type fixedValue;
value uniform (0 0 0);
lowerWall
type fixedValue;
frontAndBack
type empty;
Thanks,
Marco
om3ro is offline   Reply With Quote
[Other] Can't Shake Erros: patch type 'patch' not constraint type 'empty' BrendaEM OpenFOAM Meshing & Mesh Conversion 12 April 3, 2022 18:32
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 11:04
Fluent UDF wrong number of cells in parallel - correct in serial dralexpe Fluent UDF and Scheme Programming 7 May 17, 2018 08:26
[blockMesh] --> foam fatal error: lillo763 OpenFOAM Meshing & Mesh Conversion 0 March 5, 2014 10:27
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 21:58
