[Other] Internal Zero-thick curved plate: correcting faces orientation |
July 3, 2013, 08:52 |
Rep Power: 13 |
Hello Foamers!
My target is to estimate wind pressure on a curved plate (Attached: "Geo.png"). I am interested in pressure distribution on both sides (facing/nonfacing the wind). The approach I used to prepare the mesh is by using snappyHexMesh, in which it creates a faceZone out of the STL file, then applying createBaffles command to have 2 patches that have the same faces of the faceZone with inverted orientation. The problem is: each patch has a mix of faces that facing or not facing the wind direction (This can be demonstrated by plotting pressure distribution on one patch as shown in the attached pics "p.png", "p_with_slice.png")... i.e. I need to correct faces' normals such that: each patch should have all of its faces facing one direction. How can we orient or flip faces' normals? .. can this be done before/after meshing? Thank you very much for your time and advice. PS: This problem did not arise when we tried this procedure for a plane plate (not curved) (Please see attached pressure diagrams: "Plane_Plate.frontPatch", "Plane_Plate.backPatch") |
September 13, 2013, 12:46 |
Ripudaman Manchanda
Rep Power: 13 |
I am very interested in the problem you are trying to solve. I wish to see the plane surface as two boundaries as well. I am trying to apply this to create a static hydraulic fracture.
Can you please send me the files and the procedure you used to create the rectangular plate case that worked? Did you use SHM? Eventually I would like to be able to figure out a solution to the curved boundary issue that you are facing. But I think the plate boundary will be a good starting point for me. Thanks in advance! |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
GenerateVolumeMesh Error - Surface Wrapper Self Interacting (?) | AndreP | STAR-CCM+ | 10 | August 2, 2018 07:48 |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 10:49 |
snappyhexmesh remove blockmesh geometry | philipp1 | OpenFOAM Running, Solving & CFD | 2 | December 12, 2014 10:58 |
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 12 | May 2, 2013 10:52 |
