[mesh manipulation] Creating an openfoam mesh for paraview using openfoam designer? |
April 9, 2014, 21:16 |
Andrew Somorjai
So far I tried this much.
I used the template called cavity inside the icofoam folder and copied it to a folder called CFD. I then tried to create the mesh by doing mesh utilties->generation->blockmesh-> right click and start which generates these files inside of constant/polymesh/ boundary, faces, neighbour, owner, points now I'm not sure how to generate a .foam file to open in paraview, any ideas? |
April 10, 2014, 14:44 |
Andrew Somorjai
I did try using the echo command in windows as this thread says and then tried opening it with Paraview but then it crashed.
http://www.cfd-online.com/Forums/ope...ndows-7-a.html #10 on this thread maybe the answer, http://www.cfd-online.com/Forums/ope...r-windows.html |
August 25, 2014, 14:08 |
Mihai Racheru
Regarding your question "now I'm not sure how to generate a .foam file to open in paraview, any ideas?", if you are still interested take a look here: http://www.fm.energy.lth.se/fileadmi...rExercise1.pdf go to page 10. Simply, you have to create an empty file with *.foam (or *.openFOAM depending what version of ParaView you have on computer) extension in your case folder. For OpenFOAM under Windows, you can download version OpenFOAM 1.5 installer from here: http://sourceforge.net/projects/openfoam-mswin/ Mihai |
August 28, 2014, 16:24 |
#4 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
August 29, 2014, 04:11 |
#5 | |
Mihai Racheru
mesh generation, open foam, paraview |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[blockMesh] Creating Mesh Using SSIIM2 to OpenFoam | manuelffonseca | OpenFOAM Meshing & Mesh Conversion | 2 | January 10, 2017 14:31 |
[Commercial meshers] Creating GAMBIT mesh as multi-region for chtMultiRegion*Foam in OpenFOAM | sa har | OpenFOAM Meshing & Mesh Conversion | 1 | April 20, 2015 07:40 |
[Netgen] Problems creating OpenFOAM mesh with Netgen | sur4j | OpenFOAM Meshing & Mesh Conversion | 1 | March 22, 2014 17:03 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
