[Other] Case diverging - mesh quality or something else |
March 19, 2016, 07:42 |
Rep Power: 16 |
I am trying to solve a case that involves a fairly complex geometry (riverbed with additional structure). I received the riverbed in .stl format and it was of a rather low quality so I used SolidWorks (SW) to clean it up and model the additional structure that was needed for the geometry model. The cleaning of the riverbed model was basically just deleting triangles that involved sharp corners and unrealistic representation of the real surface, using "Filled Boundary" in SW to introduce smoother surfaces. I export the surfaces to separate .stl files and then use "cat" or "surfaceAdd" to concatenate the files together in a one .stl file with regions. This is the output of my surfaceCheck: Code:
Reading surface from "total.stl" ... Statistics: Triangles : 8365 Vertices : 4497 Bounding Box : (1e-06 1e-06 100) (122.14 249.327 114) Region Size ------ ---- inlet 2256 walli 4944 wall-river 50 wall-fleyti 253 atmo-top 240 atmo-horiz 119 outlet-river 2 outlet-fleyti 501 Surface has no illegal triangles. Triangle quality (equilateral=1, collapsed=0): 0 .. 0.05 : 0.161626 0.05 .. 0.1 : 0.0676629 0.1 .. 0.15 : 0.048416 0.15 .. 0.2 : 0.0420801 0.2 .. 0.25 : 0.0369396 0.25 .. 0.3 : 0.0425583 0.3 .. 0.35 : 0.0361028 0.35 .. 0.4 : 0.032636 0.4 .. 0.45 : 0.0276151 0.45 .. 0.5 : 0.0310819 0.5 .. 0.55 : 0.0213987 0.55 .. 0.6 : 0.0218769 0.6 .. 0.65 : 0.0237896 0.65 .. 0.7 : 0.0518828 0.7 .. 0.75 : 0.128512 0.75 .. 0.8 : 0.154094 0.8 .. 0.85 : 0.0228332 0.85 .. 0.9 : 0.01841 0.9 .. 0.95 : 0.0160191 0.95 .. 1 : 0.014465 min 2.13856e-11 for triangle 5393 max 0.999792 for triangle 2342 Edges: min 0.000280529 for edge 10494 points (96.3715 69.6728 105)(96.3717 69.6726 105) max 90.1672 for edge 11019 points (11.8551 135.061 114)(98.2565 109.275 114) Checking for points less than 1e-6 of bounding box ((122.14 249.327 14) metre) apart. Found 0 nearby points. Surface is not closed since not all edges connected to two faces: connected to one face : 902 connected to >2 faces : 11 Conflicting face labels:935 Dumping conflicting face labels to "problemFaces" Paste this into the input for surfaceSubset Number of unconnected parts : 9 Splitting surface into parts ... Writing zoning to "zone_total.vtk"... writing part 0 size 7562 to "total_0.obj" writing part 1 size 31 to "total_1.obj" writing part 2 size 72 to "total_2.obj" writing part 3 size 53 to "total_3.obj" writing part 4 size 25 to "total_4.obj" writing part 5 size 93 to "total_5.obj" writing part 6 size 15 to "total_6.obj" writing part 7 size 13 to "total_7.obj" writing part 8 size 501 to "total_8.obj" Number of zones (connected area with consistent normal) : 22 More than one normal orientation. End How critical are the "problemFaces" from the surfaceCheck output for the meshing process when originating from the situation I show in the image above, that is when adjacent faces do not share the same edge? Last edited by fusij; March 21, 2016 at 04:58. |
cfmesh, convergence, mesh quality, snappyhexmesh |
[snappyHexMesh] very bad quality snapped mesh | federicabi | OpenFOAM Meshing & Mesh Conversion | 18 | September 26, 2018 10:33 |
[ICEM] PistonVale tutorial - issues about mesh quality | Andrea1984 | ANSYS Meshing & Geometry | 5 | October 11, 2013 09:30 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
