[mesh manipulation] edgeGrading
Like Tree1Likes
  • 1 Post By Antimony
Old   March 16, 2016, 12:50
Question edgeGrading
Jack_Landis's Avatar
Jack_Landis is on a distinguished road
Hi everyone,
I'm a beginner with openFOAM.
I have some problem to understand edgeGrading...I understood that I have to define the expansion ratio for each edge of the hexahedron. They are grouped along the three directions, so the first 4 edges are all the edges along X1 and so on for X2 and X3. The thing I can't understand is to which edge corresponds each number in the parenthesis . How are they ordered?
Thanks!
Jack_Landis is offline   Reply With Quote
Old   March 17, 2016, 21:39
Antimony is on a distinguished road
I would think they are ordered from 0 to 11 within the parenthesis with edge 0 etc. being defined as described here:
http://cfd.direct/openfoam/user-guide/blockMesh/
No?
Cheers,
Antimony
Antimony is offline   Reply With Quote
Old   March 18, 2016, 05:51
Hi Antimony!
Thank you for your reply! You're right. In my case, I had this error:
Inconsistent number of faces between block pair 2 and 7
and I thought it was due to grading, but it wasn't. The problem was the way I had defined the blocks: I didn't take care of the order of vertices in the hex(...), but now I understood that this order defines axis X1, X2 and X3 for each block.
Is it correct?
Old   March 19, 2016, 10:28
Generally if you have inconsistent number of faces, it usually means that the number of cells between the different blocks has a mismatch. Unless you are duplicating vertices (and therefore duplicating edges), the common edge shared by two blocks will need to have the same number of divisions.
And yes, the ordering of the vertices determines the axes and consequently, whether or not your cells are "proper". In case your order of vertices is wrong, you will end up with cells with negative volumes which blockMesh will report during its run.
Hope this helps.
Cheers,
Antimony
siamak 60 likes this.
[blockMesh] blockMesh not producing straight lines when using edgeGrading ivan_CFD OpenFOAM Meshing & Mesh Conversion 0 February 1, 2019 09:21
[blockMesh] Multi-grading: Inconsistent point locations between blocks Flowkersma OpenFOAM Meshing & Mesh Conversion 2 August 2, 2015 14:34
Problems simulating deformation sur4j OpenFOAM 0 January 26, 2014 09:07
[blockMesh] EdgeGrading changes geomety anita OpenFOAM Meshing & Mesh Conversion 7 March 2, 2009 11:16
BlockMeshrefineMesh bug iagmanu OpenFOAM Bugs 0 February 25, 2008 08:49
