August 25, 2016, 16:44 |
gmshToFoam: missing controlDict file?
Germán Salazar
Rep Power: 11 |
First of all, excuse my ignorance...I do not use OpenFOAM, but an online search revealed mapFields...which may be of interest and my next step.
I have a colleague that would like to map some fields from one mesh to another, both representing the same geometry. The first thing I tried to do was get a simple gmsh and tried to convert it using gmshToFoam; here is the command and the error message: $ gmshToFoam m1.msh --> FOAM FATAL ERROR in Foam::findEtcFile() : could not find mandatory file 'controlDict' What's a "controlDict" file? and what should the contents of it be? Thanks in advance for any hints or full sample controlDict file ;-) gsal |
August 26, 2016, 10:07 |
controlDict is one of the dictionaries defining case. You can find examples in tutorials. Here is random one: https://github.com/OpenFOAM/OpenFOAM...em/controlDict. |
OpenFoam "Permission denied" and "command not found" problems. | iyidaniel@yahoo.co.uk | OpenFOAM Running, Solving & CFD | 11 | January 2, 2018 06:47 |
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 17:18 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 01:41 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
