[Gmsh] gmshToFoam: missing controlDict file?
Old   August 25, 2016, 16:44
Default gmshToFoam: missing controlDict file?
Germán Salazar
gsal is on a distinguished road
First of all, excuse my ignorance...I do not use OpenFOAM, but an online search revealed mapFields...which may be of interest and my next step.
I have a colleague that would like to map some fields from one mesh to another, both representing the same geometry.
The first thing I tried to do was get a simple gmsh and tried to convert it using gmshToFoam; here is the command and the error message:
$ gmshToFoam m1.msh
--> FOAM FATAL ERROR in Foam::findEtcFile() : could not find mandatory file
'controlDict'
What's a "controlDict" file? and what should the contents of it be?
Thanks in advance for any hints or full sample controlDict file ;-)
gsal
gsal is offline   Reply With Quote
Old   August 26, 2016, 10:07
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
controlDict is one of the dictionaries defining case. You can find examples in tutorials. Here is random one: https://github.com/OpenFOAM/OpenFOAM...em/controlDict.
alexeym is offline   Reply With Quote
OpenFoam "Permission denied" and "command not found" problems. iyidaniel@yahoo.co.uk OpenFOAM Running, Solving & CFD 11 January 2, 2018 06:47
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 17:18
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 01:41
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 11:44
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
