[snappyHexMesh] Thin parts in snappyHexMesh
Old   February 9, 2012, 00:43
Default Thin parts in snappyHexMesh
Barney Garrood
bgarrood is on a distinguished road
I have a simple wing with endplates I am trying to mesh. The endplates are quite large in sideview (approx 500x500mm) but thin (4mm) for the most part. I need to allow sHM to use a fine refinement around the rounded leadging and upper edges.
Currently the mesh goes to the highest refinement level (2mm cell size) where the RW endplate is thin, as if it is trying to resolve a gap, but the gap is internal so I do not want this. I cannot see a parameter in the dict file to control this behavior. Is there a way to avoid this without explicitly limiting the refinement in that area (by separating surfaces for example and setting separate refinement levels for each)?
Many thanks.
bgarrood is offline   Reply With Quote
Old   February 18, 2012, 06:51
Retired Super Moderator
Bruno Santos
Greetings Barney,
If you are trying to only use 2 cells for meshing the plate, then you'll have to use a two stage mesh generation strategy. In other words, you will have to first do the castellation and then on another run do the snapping. This is due to the way sHM works. I've reported about this issue several months ago:
Another detail is that you have to make sure that a plane of cell faces goes right though the middle of the plate, in order to make sure that sHM can figure out what you want to do.
Best regards,
Bruno
PS: I've seen your other thread about adding layers... and I've seen this as well, but I haven't been able to figure out if it's a bug or not This is why I haven't posted anything there.
[snappyHexMesh] Meshing a very thin meatus with SnappyHexMesh enginpower OpenFOAM Meshing & Mesh Conversion 29 September 9, 2017 03:46
[snappyHexMesh] snappyHexMesh: Feature snapping of thin membrane edge gooofy OpenFOAM Meshing & Mesh Conversion 7 September 19, 2016 04:29
[snappyHexMesh] Snappyhexmesh: Some parts of airfoil have a layer, others dont maero21 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 09:30
icem and thin parts?? sven82 ANSYS 1 September 26, 2010 04:09
[snappyHexMesh] SnappyHexMesh complex geometries amp thin wall parts hsieh OpenFOAM Meshing & Mesh Conversion 0 September 22, 2008 17:34
