September 20, 2012, 12:20 |
Cyclic patch problem!
Stefano
Hi foamers,
I have a problem with cyclic patches. I imported a mesh of a circular segment of a ventilated brake from gambit in OpenFoam (2.1.x) with fluent3DMeshToFoam (checkMesh is ok!). I have a periodic patch "p" (in gambit and fluent) that was divided in two patches (in openFoam): p and p_shadow. These zones in file costant/polymesh/boundary are of the "patch" type. Code:
p_shadow { type patch; nFaces 5909; startFace 1364963; } p { type patch; nFaces 5909; startFace 1370872; Code:
--> FOAM FATAL ERROR: face 607 area does not match neighbour by 0.0105585% -- possible face ordering problem. patch:p_shadow my area:5.21282e-07 neighbour area:5.21337e-07 matching tolerance:0.0001 Mesh face:1365570 fc:(0.0397671 0.198428 1.98036e-08) Neighbour fc:(0.0397671 0.160532 0.116633) If you are certain your matching is correct you can increase the 'matchTolerance' setting in the patch dictionary in the boundary file. Rerun with cyclic debug flag set for more information. From function cyclicPolyPatch::calcTransforms() in file meshes/polyMesh/polyPatches/constraint/cyclic/cyclicPolyPatch.C at line 220. FOAM exiting Code:
**Error in coupled point location: 3 faces have their 0th vertex not opposite their coupled equivalent. Average mismatch 1.34794937061e-05. <<Writing 3 faces with incorrectly matched 0th vertex to set coupledFaces Can you help me? Thank you a lot. Stefano |
October 5, 2012, 08:36 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Stefano and welcome to the forum!
I hope it's not too late... but even if it is, a similar question and answer are available here: http://www.cfd-online.com/Forums/ope...patchdict.html Best regards, Bruno
October 24, 2012, 11:23 |
Dejan Morar
I've used one geometry with some cyclic patches in OF 1.7.1 and everything worked fine. Now, when I want to use the same geometry in OF 2.1.x, it's not working. I run blockMesh and somehow geometry is created but when I run checkMesh I have the same error as SMartella **Error in coupled point location: 1150 faces have their 0th vertex not opposite their coupled equivalent. Average mismatch 0.0166011. <<Writing 1150 faces with incorrectly matched 0th vertex to set coupledFaces then when I run paraFoam, it crashes with the following error: --> FOAM FATAL ERROR: More than one patch accessing the same transform but not of the same sign. patch:fluid3_half0 transform:0 sign:-1 current transforms-1 0 0) I didn't face anything similar in OF 1.7.1 so I can't imagine what's wrong here. Problem is somewhere in the following patches: boundary ( fluid1_half0 { type cyclic; neighbourPatch fluid1_half1; transform rotational; rotationAxis (0 0 1); rotationCentre (0 -50. 0); faces ( (17 21 43 39) (21 0 22 43) ); } fluid1_half1 { type cyclic; neighbourPatch fluid1_half0; transform rotational; rotationAxis (0 0 1); rotationCentre (0 -50. 0); faces ( (19 15 37 41) (19 14 36 41) ); } .............. Any idea, suggestion...? Regards, Dejan |
November 14, 2012, 04:23 |
James Davies
More than one patch accessing the same transform but not of the same sign. patch:fluid3_half0 transform:0 sign:-1 current transforms-1 0 0) I didn't face anything similar in OF 1.7.1 so I can't imagine what's wrong here. Problem is somewhere in the following patches: boundary ( fluid1_half0 { type cyclic; neighbourPatch fluid1_half1; transform rotational; rotationAxis (0 0 1); rotationCentre (0 -50. 0); faces ( (17 21 43 39) (21 0 22 43) ); } fluid1_half1 { type cyclic; neighbourPatch fluid1_half0; transform rotational; rotationAxis (0 0 1); rotationCentre (0 -50. 0); faces ( (19 15 37 41) (19 14 36 41) ); } .............. Any idea, suggestion...? [/QUOTE] Hi Dejan, i apreciate this post is from a while back but i am also having this problem (http://www.cfd-online.com/Forums/ope...esh-error.html) Did you ever figure out a way around it? Thanks a lot James |
November 14, 2012, 04:42 |
Dejan Morar
Hi James,
and thanks for the replay. Yes, I've found a way around, I'm not using the blockMesh any more! No, I have no idea what is wrong there, maybe something with mesh numbering, but until now I didn't find how to do it on the right way. In order to understand it, one has to dive deeply into the code, but I am busy with some other things at the moment. If you find any solution to this problem, please let me know. Regards, Dejan |
June 6, 2019, 13:09 |
Utkarsh Mishra
Hey hello
Actually I am using block mesh for creating the mesh. I am having the same problem don't know what to do? It would be great if anyone could help me out |
July 26, 2023, 16:00 |
How did you solve this problem? I'm having the same issue. Thanks
openfoam ext4.0 and problem in cyclic condition | Hgholami | OpenFOAM Pre-Processing | 2 | February 19, 2019 10:53 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
[blockMesh] Cyclic BC's: Possible face ordering problem? (Channel flow) | sega | OpenFOAM Meshing & Mesh Conversion | 3 | September 28, 2010 12:46 |
chtMultiRegionFoam Tutorial | m.nichols19 | OpenFOAM | 12 | September 9, 2010 11:56 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
