[Gmsh] Trying to export both meshes from GMSH |
July 25, 2023, 05:51 |
Aran
Rep Power: 2 |
Hi everyone, I am trying to run a dynamic mesh case, so two meshes, but am struggling to see how I would be able to export both, as gmshtofoam will replace one of the meshes each time i use it. I was thinking to then run them in seperate folders and then combining them but then I would have two of each file, which I'm not entirely sure there should be?
dynamic mesh, gmsh, gmshtofoam |
[OpenFOAM.org] blockMesh issue on openfoam6 startup - ubuntu 16.04 | bjdarrer | OpenFOAM Installation | 7 | August 25, 2020 19:15 |
[OpenFOAM.org] Compilation Error with OpenFOAM-5.x using Intel Compilers | aow | OpenFOAM Installation | 4 | April 25, 2019 16:17 |
[OpenFOAM.org] Install OpenFOAM-2.1.1 on Fedora 17 | dark lancer | OpenFOAM Installation | 29 | August 20, 2016 17:49 |
[OpenFOAM.org] Can't find files when install OF2.1.1 on Mac | hewei | OpenFOAM Installation | 10 | June 3, 2016 06:50 |
Export deformed meshes from Static!!! | kamu123 | ANSYS | 1 | June 7, 2012 16:44 |
