Home > Forums > OpenFOAM Meshing & Mesh Conversion
foamMeshToFluent
Like Tree1Likes
  • 1 Post By robdeb
Old   March 28, 2013, 05:00
Default foamMeshToFluent
Robin Debroux
robdeb is on a distinguished road
Hi everybody,
I've converted my OpenFOAM mesh into a .msh file but for 2D case OpenFOAM created a 3D mesh with the "empty" condition for the front and back faces. But in Fluent, this condition doesn't exist.
I'm a new user of Fluent, so can somebody tell if there is a simple way to fix this issue?
Thanks
robdeb is offline   Reply With Quote
Old   March 28, 2013, 06:41
Arina
Akuji is on a distinguished road
Send a message via ICQ to Akuji
Originally Posted by robdeb View Post
Hi everybody,
Thanks
If I understand you correctly, you don't know why you have a boundary conditions 'empty' for the front and back faces?
If so, you might know, that OpenFOAM couldn't solve 2D task, only 3D. For the 2D cases he creates a volume task, the thickness = 1 cell. And for this volume b.c. is 'empty'.
Akuji is offline   Reply With Quote
Old   March 28, 2013, 07:07
Robin Debroux
thanks for your reply.
I had understood what OpenFOAM was doing. But when I convert my mesh to Fluent, it "sees" it as a 3D body with my front and back faces but I can't put an equivalent condition that does the same as "empty". So I can't solve my 2D problem with Fluent.
Old   March 28, 2013, 07:35
Post
Tushar
Tushar@cfd is on a distinguished road
Well, if am not wrong you are converting from OpenFOAM to Fluent.
Now, the problem is OpenFOAM will only read the 3D mesh geometry, so as a user for 2D simulation one has to make 3D geometry in OpenFOAM. Since, you have made a 3D geometry by using blockmesh code so, when you will import in fluent it will show you the same.
For the case of fluent, the condition is different it needs 2D mesh for 2D simulation and 3D mesh for 3D simulation.
This means, you won't be able to call (or import) a case of 2D mesh/simulation of OpenFOAM for the 2D simulation of fluent.
I hope you got the point.
Tushar@cfd is offline   Reply With Quote
Old   March 28, 2013, 08:30
Robin Debroux
Yes, I got it.
So there's no way to fix the problem, that's what I wanted to know.
Thank you very much.
Old   April 16, 2013, 16:43
Banned
ehsan
immortality is an unknown quantity at this point
hi
I have the same issue.
Did you resolved the problem?
immortality is offline   Reply With Quote
Old   April 17, 2013, 07:58
Robin Debroux
Yes, if you use the "symmetry condition", it will solve a 2D case as with the "empty condition" of OpenFOAM
immortality likes this.
Thread Tools
Trackbacks are On
foamMeshToFluent does not write zones doubtsincfd OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... 3 October 18, 2012 15:31
Using foamMeshToFluent Rickard.Solsjo ANSYS 0 March 9, 2012 02:54
foamMeshToFluent not working with snappyhexmesh calim_cfd OpenFOAM Mesh Utilities 3 January 9, 2012 09:10
FoamMeshToFluent 2D axi frackowi OpenFOAM Post-Processing 1 February 12, 2008 20:45
FoamMeshToFluent tutlhino OpenFOAM Post-Processing 1 June 11, 2007 07:51
