[Commercial meshers] Star CCM+ mesh to .msh format for use in Fluent |
May 26, 2016, 15:06 |
Shubham Deshmukh
Rep Power: 10 |
I am trying to convert .ccm mesh to fluent readable format .msh through OpenFOAM v3.0+ . I am completely new to OpenFOAM and using it on Windows 8.1 using Docker tool. Can anyone please help me to perform the mesh conversion? Would be really thankful! Shubham |
May 31, 2016, 10:31 |
Stefano Gaggero
Rep Power: 13 |
Dear Shubham,
you have to install an optional plugin (ccm26ToFoam) in order to be able to convert meshes from ccm+ to OpenFOAM format. Here in the forum you can find some dedicated pages that explain how to obtain this plugin and install it. Also openfoamwiki is useful. Good luck, Stefano |
June 1, 2016, 16:00 |
Star CCM+ mesh Imported into Fluent
Shubham Deshmukh
Rep Power: 10 |
Thanks Stefano!
Well I actually got a better option than using OPENFOAM, directly convert the star ccm+ mesh (I used in 3D) into Tecplot 360 (.plt) format which is readable in Fluent solver. For future reference: In Star CCM+, Export > Mesh Only (Select all boundaries and regions) > save in Tecplot 360 (.plt). In ANSYS Workbench, Component Systems (Left pane) > Fluent > Setup > (opens Fluent solver) > File >Import > Tecplot...!!! Shubham |
April 9, 2020, 08:40 |
#4 | |
Rep Power: 10 |
Also, does FLUENT have a known size limiting for importing meshes? I was able to export from STARCCM to *.case with the 220E+06 cell mesh, but FLUENT has been importing the file for 48 hours. Last edited by miragemobile; April 10, 2020 at 20:25. |
[ANSYS Meshing] Export mesh ( .msh) in a ASCII format | pedroxramos | ANSYS Meshing & Geometry | 14 | June 20, 2020 12:30 |
Can fluent tet mesh be converted into Polyhedral mesh in CCM? | jealor | STAR-CCM+ | 7 | January 10, 2018 05:25 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
How to convert STAR mesh into FLUENT mesh ? | Jihwan | Siemens | 8 | November 10, 2004 04:11 |
Convert FLUENT mesh to some other format for STAR? | Jiaying Xu | FLUENT | 3 | December 5, 2002 08:15 |
