[snappyHexMesh] meshing with snappy: im a very beginner
Old   October 1, 2009, 06:17
Default meshing with snappy: im a very beginner
Samuele Z
samiam1000 is on a distinguished road
Hi all,
I am a very beginner with OpenFOAM and I do have a stl model that I wanna mesh.
So, which are the steps to do? I wanna use SnappyHexMesh in order to be able to run the OpenFOAM analysis, later.
What I am asking you is: could you suggest me the steps I had to follow?
Or, even simpler, could you explain me how I can run the motorbike example in the tutorial?
Thanks a lot,
samuele
samiam1000 is offline   Reply With Quote
Old   October 1, 2009, 11:22
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
Hi Samuele,
You can find snappyHexMesh described in the User's Guide.
But:
You could start by copying the '$FOAM_TUTORIALS/snappyHexMesh/motorBike' directory to your '$FOAM_RUN' directory.
Basically the motorBike case consists of a man on a motorbike (STL file), and presumably the aerodynamics wish to be looked at so a large box is created around the man on the motorbike (like a wind tunnel).
The way snappyHexMesh works is that it meshes the box first with blockMesh (or any other mesher) and then cuts the STL out of that box and either keeps the part of the mesh that it cut out or the mesh that remains.
It then 'snaps' the castellated surface to the STL (ie it smoothes the mesh at the STL surface).
Then an optional step is to add a boundary layer.
So enter the '$FOAM_RUN/motorBike' and execute 'blockMesh' - this creates the box around the motorbike.
Then execute snappyHexMesh, which does its thing and creates the new mesh in the next time directory. I think time '1' is the castellated mesh, time '2' is the snapped mesh and time '3' has a boundary layer. You have to zoom in close to see the motorbike.
So to use your own STL, place it in the 'constant/triSurface' directory and then edit the 'snappyHexMeshDict' in the 'system' directory appropriately. You can change the refinement level etc and turn on/off boundary layers.
Hope it helps,
Philip C
bigphil is offline   Reply With Quote
Old   October 1, 2009, 11:35
Default Thank
Samuele Z
Ok, it really helps.
Can you give me any suggestion about the layer feature?
I have tryied to delete them, but it tells me that there's something wrong.
Is the point explained in the user guide?
Thanks a lot,
samuele
Old   October 1, 2009, 11:45
bigphil's Avatar
Philip Cardiff
At the top of the snappyHexMeshDict,
you can set the layers feature to on or off.
Don't delete the layers stuff from the dictionary.
I think you can turn the other two steps on or off there too.
Philip
Old   October 1, 2009, 11:52
Samuele Z
Just a question: but do you think that SnappyHexMesh is a good choice???
Thanks a lot,
samuele.
Old   October 1, 2009, 12:00
bigphil's Avatar
Philip Cardiff
There are a lot of meshing softwares out there, so it really depends on what you want to do.
I haven't used snappyHexMesh too much, and I'd have to do some mesh comparison studies before I could really say, but it's easy enough to use once you figure it out, and it's built in to OpenFOAM. You'll probably have to mess around with the mesh refinement until it's right and you get a mesh independent result.
But as I said there are lots of software choices out there and it depends what you want to do.
Philip
Old   November 12, 2009, 04:22
Eridian
Hello everyone,
I'm a newbie to the OpenFOAM world and I'd like to make my first own meshes. (I've already completed all the tutorials and excercises in the User's and Programmer's Guid.) I'm on
To start off, I have two questions:
Like samiam1000, I wanted to make the Motorbike Tutorial. When I executed snappyHesMesh, it started fine, but it ended with following message and aborted:
Create time
Create mesh for time = 3
Read mesh in = 3.91 s
Overall mesh bounding box : (-5 -4 0) (15 4 8)
Relative tolerance : 1e-06
Absolute matching distance : 2.29783e-05
Reading refinement surfaces.
Read refinement surfaces in = 2.05 s
Reading refinement shells.
Refinement level 4 for all cells inside refinementBox
Read refinement shells in = 0 s
Setting refinement level of surface to be consistent with shells.
Checked shell refinement in = 0.02 s
Determining initial surface intersections
Edge intersection testing:
Number of edges : 1065751
Number of edges to retest : 1065751
Number of intersected edges : 30128
Calculated surface intersections in = 6.4 s
Initial mesh : cells:339662 faces:1065751 points:392459
Cells per refinement level:
0 934
1 1720
2 5040
3 9472
4 131655
5 24036
6 166805
Adding patches for surface regions
Patch Region
motorBike:
5 motorBike_frt-fairing:001%1
6 motorBike_windshield:002%2
7 motorBike_rr-wh-rim:005%5
8 motorBike_rr-wh-rim:010%10
9 motorBike_fr-wh-rim:011%11
10 motorBike_fr-wh-brake-disk:012%12
11 motorBike_frame:016-shadow%13
12 motorBike_rear-susp:014%14
13 motorBike_rear-susp:014-shadow%15
14 motorBike_frame:016%16
15 motorBike_rr-wh-rim:005-shadow%17
16 motorBike_rr-wh-chain-hub:022%22
17 motorBike_rearseat%24
18 motorBike_frt-fairing%25
19 motorBike_windshield%26
20 motorBike_headlights%27
21 motorBike_driversseat%28
22 motorBike_rear-body%29
23 motorBike_fuel-tank%30
24 motorBike_exhaust%31
25 motorBike_rr-wh-rim%32
26 motorBike_fr-mud-guard%33
27 motorBike_fr-wh-rim%34
28 motorBike_fr-wh-brake-disk%35
29 motorBike_fr-brake-caliper%36
30 motorBike_fr-wh-tyre%37
31 motorBike_hbars%38
32 motorBike_fr-forks%39
33 motorBike_chain%40
34 motorBike_rr-wh-tyre%41
35 motorBike_square-dial%42
36 motorBike_round-dial%43
37 motorBike_dial-holder%44
38 motorBike_rear-susp%45
39 motorBike_rear-brake-lights%46
40 motorBike_rear-light-bracket%47
41 motorBike_frame%48
42 motorBike_rear-mud-guard%49
43 motorBike_rear-susp-spring-damp%50
44 motorBike_fairing-inner-plate%51
45 motorBike_clutch-housing%52
46 motorBike_radiator%53
47 motorBike_water-pipe%54
48 motorBike_water-pump%55
49 motorBike_engine%56
50 motorBike_rear-shock-link%57
51 motorBike_rear-brake-fluid-pot-bracket%58
52 motorBike_rear-brake-fluid-pot%59
53 motorBike_footpeg%60
54 motorBike_rr-wh-chain-hub%61
55 motorBike_rear-brake-caliper%62
56 motorBike_rider-helmet%65
57 motorBike_rider-visor%66
58 motorBike_rider-boots%67
59 motorBike_rider-gloves%68
60 motorBike_rider-body%69
61 motorBike_frame:0%70
62 motorBike_frt-fairing:001-shadow%74
63 motorBike_windshield-shadow%75
64 motorBike_fr-mud-guard-shadow%81
65 motorBike_fr-wh-brake-disk-shadow%83
66 motorBike_rear-mud-guard-shadow%84
67 motorBike_rear-susp-spring-damp-shadow%85
68 motorBike_radiator-shadow%86
69 motorBike_rear-shock-link-shadow%87
70 motorBike_rear-brake-fluid-pot-bracket-shadow%88
71 motorBike_rr-wh-chain-hub-shadow%89
Added patches in = 0.01 s
Selecting decompositionMethod hierarchical
Refinement phase
Found point (3 3 0.43) in cell 169409 on processor 0
Reading external feature lines.
Read feature lines in = 0 s
Surface refinement iteration 0
Marked for refinement due to surface intersection : 0 cells.
Marked for refinement due to curvature/regions : 14 cells.
Determined cells to refine in = 0.26 s
Selected for refinement : 14 cells (out of 339662)
hexRef8 : Dumping cell as obj to "/home/fa1/OpenFOAM/eschirach/run/tutorials/incompressible/simpleFoam/motorBike/cell_334436.obj"
cell 334436 of level 5 uses more than 8 points of equal or lower level
Points so far:8(20342 45178 56201 56206 83600 83601 388097 388098)#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/opt/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 Foam::hexRef8::setRefinement(Foam::List<int> const&, Foam:olyTopoChange&) in "/opt/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libdynamicMesh.so"
#3 Foam::meshRefinement::refine(Foam::List<int> const&) in "/opt/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libautoMesh.so"
#4 Foam::meshRefinement::refineAndBalance(Foam::strin g const&, Foam::decompositionMethod&, Foam::fvMeshDistribute&, Foam::List<int> const&) in "/opt/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libautoMesh.so"
#5 Foam::autoRefineDriver::surfaceOnlyRefine(Foam::re finementParameters const&, int) in "/opt/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libautoMesh.so"
#6 Foam::autoRefineDriver::doRefine(Foam::dictionary const&, Foam::refinementParameters const&, bool, Foam::dictionary const&) in "/opt/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libautoMesh.so"
#7 main in "/opt/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/snappyHexMesh"
#8 __libc_start_main in "/lib/libc.so.6"
#9 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/x86_64/elf/start.S:116
From function hexRef8::setRefinement(const labelList&, polyTopoChange&)
in file polyTopoChange/polyTopoChange/hexRef8.C at line 3481.
FOAM aborting
Could someone please tell me what this exactly means? I could start ParaView on the mesh and see the motorbike in it's third iteration.
My second question:
I have an .stl file and I want to mesh it with snappy. I created a folder and made everything that's in the User's Guide. But I don't realy understand how to deal with the snappyHexMeshDict dictionary. How can I tell snappy, that I need the interior mesh for my calculation (I have to mesh a bended tube). What about the boundary definitions? How do I creat them? What exactly do I need to define?
Best greetings from a sunny autumn day in Munich,
Eridian
EDIT
I have one more question. I tried to adapt the motorbike case to my own test case. When I try to run sHM, I reviece the following error:
Create time
Create mesh for time = 0
Read mesh in = 0.04 s
--> FOAM Warning :
From function entry::getKeyword(keyType&, Istream&)
in file db/dictionary/entry/entryIO.C at line 78
Reading /home/fa1/OpenFOAM/eschirach/run/testmodelle/uebung_box/box_stl/system/snappyHexMeshDict
found on line 33 the punctuation token '{'
expected either } or EOF
keyword castellatedMeshControls is undefined in dictionary "/home/fa1/OpenFOAM/eschirach/run/testmodelle/uebung_box/box_stl/system/snappyHexMeshDict"
file: /home/fa1/OpenFOAM/eschirach/run/testmodelle/uebung_box/box_stl/system/snappyHexMeshDict from line 18 to line 35.
From function dictionary::subDict(const word& keyword)
in file db/dictionary/dictionary.C at line 467.
FOAM exiting
#1 Error
The command lines in snappyHexMeshDict are (line 29 - 44)
geometry
box.stl;
type triSurfaceMesh;
name box;
refinementBox
type searchableBox;
min (-1.0 -0.7 0.0);
max ( 8.0 0.7 2.5);
I don't know, why there should be an "}" or an "EOF" in line 33. What is actually an "EOF"?
#2 Error
I don't unterstand, why the castellatedMeshControls seems to be undefined. All braces are closed and I did the same things in there like in the motorbike tutorial. Moreover I tried zu set the boundaryLayers on "false", because, I'm not sure what to enter there. Can I delete now the code from the sHMDict or must I leave in there - but then, with which Information in it?
A lot of questions, I know, but I'd realy appreciate it, if someone could help me!
Old   November 16, 2009, 21:04
stark22 is on a distinguished road
Philip,
I have successfully generated the mesh ( I think, i ran blockmesh and snappyhexmesh with no errors). I'm still not able to see the bike in parefoam any suggestions on to adjust the settings to see it?
Also, this tutorial is equipped with the appropriate files to run a flow case correct?
Thank you
stark22 is offline   Reply With Quote
Old   November 17, 2009, 05:32
bigphil's Avatar
Philip Cardiff
Stark22,
It sounds as if it ran fine. The bike is very small relative to the size of the flow domain, so as far as I can remember you set the view to wireframe and zoom in very close to the centre of the bottom of the domain.
I have attached a picture of the zoomed out geometry (you can see the motorbike is where the mesh is refined at the bottom) and the zoomed in view where you can see the motorbike.
I have never ran the motorbike case so I don't know but I'm sure you can give it a try.
Philip
Old   November 17, 2009, 05:59
bigphil's Avatar
Philip Cardiff
Hi Eridian,
I can't answer all your questions but hopefully I can be of some help.
Firstly, I am not sure why snappyHexMesh ended in an error - possibly it ran out of RAM, have you very little? - i'm not sure, but I have attached the snappyHexMeshDict from my OF-1.5-dev case that works for me, so you could try that.
To tell snappy to keep the interior part of your mesh, just specify 'locationInMesh' (line 155 I think) to be a point inside that part of the mesh you want to keep.
So you specify this point and you specify the STL surface(s) you are using and the refinement on these surfaces.
Specify boundary patches is a slightly more difficult, I think you can find some answers by searching the forum. You can define patches on your blockMesh box and these patches will be kept (if theyre still left).
I am not sure what you edited in snappyHexMeshDict but there are three parts to snappy that can be turned on or off at the top: castellate, snapping and addLayer (or something like that) so if you don't want one just set to no but don't delete things in the dictionary.
Hopefully it helps a bit,
Philip
Old   November 17, 2009, 08:56
Philip,
Thanks for the response.
I did set the view to wireframe but I didn't obtain the same mesh model as you do. My grid is much coarser and doesn't contain the refined region where the motorbike is located. I must be doing something wrong although there are no error messages after running snappyhexmesh. Im running a dual core (intel) 64 bit OS with 8G of memory. It takes about 187s for the mesh to be generatated. How long does it take you to create this mesh on your system? Ill keep working at it.
Thanks again
Old   November 17, 2009, 09:01
bigphil's Avatar
Philip Cardiff
Stark22,
Ye mine takes about the same length of time on my machine.
Hmmnn did you change to the last time step? The final mesh will be in the third timestep usually - the first will be just the blockMesh, the second will be the castellated mesh and the third will be the snapped mesh.
Maybe that'll work,
Philip
Old   November 17, 2009, 21:03
Philip,
When I run blockmesh and snappyHexMesh the following is created:
Folders 1, 2, 3 and file motorBike.OpenFoam.
If I change directories to folder "3" and run paraFoam, it will not run. It seems parafoam will only run the motorBike.OpenFoam file that was in the original directory. When I run this file it looks like it only generates to the overall fluid domain boundary. Any thoughts.
I really appreciate your help.
Old   November 18, 2009, 06:11
bigphil's Avatar
Philip Cardiff
Stark22,
I'm not sure what the motorbike.OpenFOAM file is, I suspect it is created by paraFoam. I don't use paraFoam, I use 'foamToVTK' and then open the VTK file in 'paraview'.
So you could try that - from the case directory run 'foamToVTK', then run 'paraview'. In paraview, go to 'open' and go into the 'VTK' directory that was created and open the '*.vtk' file.
It should then work if you go to the last time-step.
Or you could try:
delete your mesh by 'rm -rf constant/polyMesh'
then move the mesh in '3' to the constant directory 'mv 3/polyMesh constant/'
then remove the time directories 'rm -rf 1 2 3'
then when you run 'paraFoam' it should work.
Philip
Old   November 18, 2009, 07:30
Philip,
I ran foamtoVTK and then launched paraview (parafoam is the script that launches paraview). I opened the last time step mesh *.vtk (3) and sure enough it worked.
Thank for your help I really appreciate it. Now I just need to run an analysis!
Old   November 18, 2009, 07:42
bigphil's Avatar
Philip Cardiff
No problem,
good luck!
Philip
Old   November 18, 2009, 20:54
Philip,
I know this is off topic but if you generate the motorbike mesh and then run simpleFoam it will generate solution files. The last solution file is "500" which I believe relates to the time step specified in one of the boundary condition directories (I forget the actual name, I believe it was in the "systems" directory).
How then do you post process it in paraview?
Thanks, and sorry to the rest for going off topic.
Old   November 19, 2009, 05:20
bigphil's Avatar
Philip Cardiff
Stark22,
I am not sure what your question is exactly, but the first tutorial in the OpenFOAM user's guide (http://foam.sourceforge.net/doc/Guides-a4/UserGuide.pdf) explains clearly how to run a simple fluid simulation and how to perform post-processing with paraview (streamlines, pressure/velocity plots, glyphs).
I am guessing that the same methods can be applied to your case.
Philip
Old   November 19, 2009, 06:44
I did the cavity flow tutorial but I'll keep trying. Thanks for the help.
Old   November 23, 2009, 05:03
sErik is on a distinguished road
Hello everyone,
I'm trying to mesh a test file i created, but I recieve two different errors:
It is about the locationInMesh in the castellatedMeshControls dictionary. This happens, when I enter (580 430 -45) for the locaitonInMesh
Patch Region
Rohrelement:
5 Rohrelement_NASTRAN
Added patches in = 0 s
Refinement phase
Point (580 430 -45) is not inside the mesh or on a face or edge.
Bounding box of the mesh-390 0 -150) (2190 584 50)
From function refinementParameters::findCells(const polyMesh&) const
in file autoHexMesh/autoHexMeshDriver/refinementParameters/refinementParameters.C at line 104.
FOAM exiting
I don't understand, why the point isn't inside the mesh, althoug it is included in the bounding box of the mesh?
When entering (188 270 -50) for locationInMesh, I get this error:
Splitting mesh at surface intersections
Introducing baffles for 2256 faces that are intersected by the surface.
Number of edges : 55094
Number of edges to retest : 9877
Number of intersected edges : 2292
Created baffles in = 0.12 s
After introducing baffles : cells:16447 faces:55094 points:22330
0 715
1 1588
2 3822
3 10322
Introducing baffles to block off problem cells
#1 Foam::sigSegv::sigSegvHandler(int) in "/opt/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 ?? in "/lib/libc.so.6"
#3 Foam:rimitiveMesh:ointCells(int, Foam:ynamicList<int, 0u, 2u, 1u>&) const in "/opt/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#4 Foam::meshRefinement::markFacesOnProblemCells(Foam ::dictionary const&, bool, Foam::Field<double> const&, Foam::List<int> const&) const in "/opt/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libautoMesh.so"
#5 Foam::meshRefinement::baffleAndSplitMesh(bool, bool, Foam::Field<double> const&, bool, Foam::dictionary const&, Foam::Time&, Foam::List<int> const&, Foam::Vector<double> const&) in "/opt/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libautoMesh.so"
#6 Foam::autoRefineDriver::baffleAndSplitMesh(Foam::r efinementParameters const&, bool, Foam::dictionary const&) in "/opt/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libautoMesh.so"
#7 Foam::autoRefineDriver::doRefine(Foam::dictionary const&, Foam::refinementParameters const&, bool, Foam::dictionary const&) in "/opt/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libautoMesh.so"
#8 main in "/opt/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/snappyHexMesh"
#9 __libc_start_main in "/lib/libc.so.6"
#10 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/x86_64/elf/start.S:116
Speicherzugriffsfehler
The file is located in ".../run/testmodelle/pisoFoam/les/rohrelement_stl". I don't know what the problem could be?
sErik is offline   Reply With Quote
[snappyHexMesh] snappyHexMesh stops meshing Tensian OpenFOAM Meshing & Mesh Conversion 2 January 26, 2014 09:54
Help me to choose between Ansys Meshing, Fluent Meshing or ICEM ? pipolaki ANSYS 0 December 6, 2013 08:12
[snappyHexMesh] Meshing NACA airFoil with snappy Paolo.F OpenFOAM Meshing & Mesh Conversion 6 October 8, 2013 04:52
Meshing locks workbench window. andy2o CFX 0 February 1, 2008 05:01
