[Gmsh] Unable to Convert .stp to .msh file FOAM FATAL IO ERROR
Old   March 1, 2012, 14:55
Default Unable to Convert .stp to .msh file FOAM FATAL IO ERROR
Brandon Lien
SrStompy is on a distinguished road
Hi, i have been trying to get my .stp to .msh. And somewhere in here I am messing up as when i run gmshToFoam I keep getting errors. The most recent being.
--> FOAM FATAL IO ERROR:
No cells read from file "testmodel"
Does your file specify any 3D elements (hex=5, prism=6, pyramid=7, tet=4)?
Perhaps you have not exported the 3D elements?
As far as steps I have taken, I have basically just opened gmsh, Merge, grabbing my .stp file. Then used the 3D, and then 3D optimizing(netgen). Saving that as a .msh and trying the gmshToFoam where i receive the above error.
I tried to attach the .stp file, but it exceeds the forum limit. If you need/want this I can email it.
Thanks
SrStompy is offline   Reply With Quote
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 13:21
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 03:30
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 21:53
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 18:45
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 01:41
