[General] Convert from Cartesian to Cylindrical |
June 10, 2015, 12:54 |
Alexey
Hello!
I solved StressAnalysis problem on OpenFOAM. I have sigma in Cartesian coordinates and I can see sigma in Paraview. But I want to see sigma in Cylindrical coordinates. How very easy do this? May be there is a function in Paraview which allowed sigam tensor convert from Cartesian coordinates to Cylindrical. |
June 12, 2015, 18:51 |
Alta Dynamics
Rep Power: 10 |
I don't know if there is an existing function/filter in PV to accomplish this. But it's possible to perform tensor transformation. I can think of two ways:
1. Use the "programmable filter" to enter the several lines of code (python script) to perform the transformation. You would hard code the angles. This is a relatively easy approach. 2. Write a filter in C++ to do this. You can enter the angles in the interface. This approach is daunting if you have never done similar things before. |
Cartesian to cylindrical velocity field conversion | francois | OpenFOAM Post-Processing | 11 | November 30, 2017 05:52 |
2-D Cylindrical vs Cartesian Discretization | plinian | Main CFD Forum | 4 | March 4, 2017 05:15 |
Converting cylindrical anisotropic diffusivity comonents into the cartesian setting | mcgintygs | OpenFOAM | 0 | January 29, 2014 08:47 |
cylindrical coordinate vs cartesian coordinate | Lam | FLUENT | 10 | May 11, 2013 13:05 |
3D axisymmetric flow in cylindrical coordinate = 2D cartesian flow? | shubiaohewan | Main CFD Forum | 10 | May 2, 2013 14:08 |
