Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Pvpython ubuntu deb package
Old   January 22, 2014, 14:21
Default Pvpython ubuntu deb package
Anonymous
maero21 is on a distinguished road
Dear Openfoam users,
I have installed the ubuntu dev package using the instructions from the OpenFOAM website. However, now I want to use pvpython and every time I get an error: ImportError: No module named vtkCommonPython. I read somewhere that this is due to the fact that I installed the deb package. However, since I already installed OpenFoam-2.2.2 I cannot install it again from source, right?
Any ideas on how I could get pvpython to work?
Thanks!
By the way, I am running Ubuntu 12.04.
maero21 is offline   Reply With Quote
Old   January 22, 2014, 18:34
Retired Super Moderator
Bruno Santos
Greetings maero21,
Check this bug report: http://www.openfoam.org/mantisbt/view.php?id=969 - the first comment provides information on where to find a fix.
Best regards,
Bruno
Old   January 23, 2014, 10:53
Anonymous
Dear Bruno,
Thank you very much I can know run pvpython from the terminal and do some examples. However when I use the trace option in Paraview and then try to run that script through pvpython, I keep getting this error:
 Inconsistency detected by ld.so: dl-close.c: 759: _dl_close: Assertion `map->l_init_called' failed!
Did I do something wrong or is the installation not correct?
By the way, this is the script I am trying to run:
try: paraview.simple
except: from paraview.simple import *
paraview.simple._DisableFirstRenderCameraReset()
allPatches_100_vtk = LegacyVTKReader( FileNames=['/home/CFD/Documents/motorBike/VTK/allPatches/allPatches_100.vtk'] )
track0_p_k_vtk = LegacyVTKReader( FileNames=['/home/CFD/Documents/motorBike/postProcessing/sets/wallBoundedStreamLines/100/track0_p_k.vtk'] )
RenderView1 = GetRenderView()
SetActiveSource(allPatches_100_vtk)
DataRepresentation2 = Show()
DataRepresentation2.EdgeColor = [0.0, 0.0, 0.5000076295109483]
RenderView1.CenterOfRotation = [0.7296143770217896, -0.008860617876052856, 0.6756079792976379]
SetActiveSource(track0_p_k_vtk)
DataRepresentation3 = Show()
DataRepresentation3.EdgeColor = [0.0, 0.0, 0.5000076295109483]
WriteImage('/home/CFD/Documents/motorBike/test1.png')
RenderView1.CameraPosition = [0.7296143770217896, -0.008860617876052856, 5.586333373144778]
RenderView1.CameraFocalPoint = [0.7296143770217896, -0.008860617876052856, 0.6756079792976379]
RenderView1.CameraClippingRange = [3.5171582611063688, 6.676784262895431]
RenderView1.CameraParallelScale = 1.270989257196217
Render()
Kind regards
Old   January 26, 2014, 07:55
Bruno Santos
Hi maero21,
I didn't read carefully your post the other day and didn't answer to this question:
You can have both installations if you want to. You can find instructions on this topic here: http://openfoamwiki.net/index.php/In...nFOAM_versions
I vaguely remember getting that message when ParaView was closing... which was already too late to be of any matter, since I had already used ParaView with success.
According to this post: http://www.cfd-online.com/Forums/ope...tml#post364741 post #3, removing the package "qt-at-spi" might fix the problem:
sudo apt-get remove qt-at-spi
By the way, do you have Ubuntu 12.04 x86_64 or i686 installed? You can check by running:
uname -m
Best regards,
Bruno
[foam-extend.org] paraview not runing? (foam extended 3.2 and ubuntu 15.04) Milan2013 OpenFOAM Installation 23 April 20, 2017 05:49
Prolem installing OpenFOAM Ver 2.3.0 source in Ubuntu 13.1.0 on VMware zandi OpenFOAM Installation 5 March 31, 2014 03:57
OF 1.6 ext on Ubuntu 12.10 (64 bit) compilation errors dreamilam OpenFOAM Installation 7 April 21, 2013 05:43
Problem? with Installation of OpenFOAM 2.1.0 on to Ubuntu 10.4.4 VirtualBox Stubby OpenFOAM Installation 8 March 5, 2012 15:12
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
