[OpenFOAM] After setting MeshScalingFactor in Gmsh
Old   October 19, 2008, 10:14
Default After setting MeshScalingFactor in Gmsh
ZHOU Bin
Location: Nanjing/Torino, Nanjing/Piemente, China/Italy
zhoubinwx is on a distinguished road
Send a message via ICQ to zhoubinwx Send a message via MSN to zhoubinwx Send a message via Skype™ to zhoubinwx
Dear all,
I want to set the dimension in Gmsh instead of using "transformPoints -scale '(1E-6 1E-6 1E-6)'" after gmshTofoam, I use "Mesh.ScalingFactor = 1e-06;"
I could see that the nodes data are fine, but I could not see the geometry in paraFoam.
When I disable this "Mesh.ScalingFactor = 1e-06;", I could see the geometry quite well.
Therefore, I would like to post a simple case here. This attached you could see the geometry, then when you disable the comment "Mesh.ScalingFactor = 1e-06;" in .geo file, you will have the problem.
box.
If you know it, please let me know, thank you.
Best regards,
Bin
zhoubinwx is offline   Reply With Quote
Old   October 19, 2008, 10:15
Default sorry, the attached case is he
ZHOU Bin
sorry, the attached case is here:
box_paraFoam.geo
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 09:53
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 21:58
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 10:56
Warning 097- AB Siemens 6 November 15, 2004 04:41
