Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Some problem with paraview
Old   November 22, 2005, 04:24
Default Some problem with paraview
thermo
I've just installed OpenFOAM, which can calculate normally. But there seem some problems with paraview. At first,when I execute paraview, it simply tells that '.../paraview: cannot execute binary file'. So I download another paraview(version-2.2.1) instead. This time,the paraview can work! But a new problem arises,when execute:
paraFoam ... ...
it refers:
ErrorMessage
# Error or warning: ERROR: In /home/amy/ParaViewReleaseRoot/paraview-2.2.1/Utilities/VTKClientServer/vtkClient ServerInterpreter.cxx, line 866
vtkClientServerInterpreter (0x805cf40): Cannot find module "libPVFoamReader.so". The following paths were searched:
/home/wzx/OpenFOAM/linux/paraview-2.2.0/lib/paraview-2.2
/home/wzx/OpenFOAM/OpenFOAM-1.2/lib/linuxGcc4Opt/lam-7.1.1
/home/wzx/OpenFOAM/OpenFOAM-1.2/src/lam-7.1.1/platforms/linuxGcc4Opt/lib
/home/wzx/OpenFOAM/linux/gcc-4.0.1/lib
/home/wzx/OpenFOAM/wzx-1.2/lib/linuxGcc4Opt
/opt/intel/fc/9.0/lib
/home/wzx/OpenFOAM/OpenFOAM-1.2/src/lam-7.1.1/platforms/linuxGcc4Opt/bin
/home/wzx/OpenFOAM/OpenFOAM-1.2/src/mico-2.3.11/platforms/linuxGcc4Opt/bin
/home/wzx/OpenFOAM/linux/j2sdk1.4.2_05/bin
/home/wzx/OpenFOAM/linux/gcc-4.0.1/bin
/home/wzx/OpenFOAM/wzx-1.2/applications/bin/linuxGcc4Opt
/home/wzx/OpenFOAM/OpenFOAM-1.2/applications/bin/linuxGcc4Opt
/home/wzx/OpenFOAM/OpenFOAM-1.2/wmake
/home/wzx/OpenFOAM/OpenFOAM-1.2/bin
/opt/intel/fc/9.0/bin
/usr/local/bin
/usr/bin
/usr/X11R6/bin
/bin
/usr/games
/opt/gnome/bin
/opt/kde3/bin
/usr/lib/mit/bin
/usr/lib/mit/sbin
/home/wzx/OpenFOAM/linux/paraview-2.2.0/bin
/usr/lib
/usr/lib/vtk
/usr/local/lib
/usr/local/lib/vtk
ERROR: In /home/amy/ParaViewReleaseRoot/paraview-2.2.1/GUI/Client/vtkPVXMLPackageParser.cx x, line 677
vtkPVXMLPackageParser (0x8636630): Error loading Library component PVFoamReader
ErrorMessage end
There isn't the dir '/home/amy...' at all. And there is no 'PVFoamReader' too.
who can help me to solve it, thanks a lot.
Old   November 22, 2005, 07:41
Default Hi, here it is, I would thi
Niklas Wikstrom
wikstrom is on a distinguished road
here it is, I would think (from above):
You have to set $ParaView_VERSION in
$WM_PROJECT_DIR/$FOAM_DOT_DIR/apps/paraView/{bashrc,cshrc}
Assuming that you keep your new paraview-2.2.1 in $WM_PROJECT_INST_DIR/$WM_ARCH/
wikstrom is offline   Reply With Quote
Old   November 22, 2005, 09:28
Default I tried as suggested,but it ha
thermo
I tried as suggested,but it has no effect. The situation looks like the same as I posted at first.
hmmm,it mainly mentions:
vtkPVXMLPackageParser (0x864ddb0): Error loading Library component PVFoamReader
/home/wzx/OpenFOAM/OpenFOAM-1.2/bin/paraFoam: line 57: 3608 section wrong paraview paraFoam.pvs
The dir, '/home/amy/....', seems strange. I cannot find it at all.
Execute 'paraFoam paraFoam.pvs' directly, paraview starts,but ends at once, hehe.
Old   November 22, 2005, 09:40
Default The /home/amy-part comes from
Rasmus Hemph
hemph is on a distinguished road
The /home/amy-part comes from the directory where the PVFoamReader was built originally, it is ok. You must use the paraview supplied with OpenFoam to be able to use paraFoam. Here it looks like you are using the version you downloaded from paraview homepage instead. If you wish, you can run foamToVTK on your case and use paraview to look at the results.
Did you download the correct paraview for your architecture from OpenFOAM download page?
hemph is offline   Reply With Quote
Old   November 22, 2005, 09:46
Default en,i did download the paraview
thermo
en,i did download the paraview supplied with OpenFoam...but it didn't work at all.
it happens that another person meet the same problem, look down.
Old   November 22, 2005, 09:54
Default I downloaded paraview for linu
Rasmus Hemph
I downloaded paraview for linux a couple of days ago without any problems (for OpenFOAM-1.2). (I believe the problem of below is different, paraview was not found which indicate some error in the installation process.)
My libPVFoamReader.so is in
${HOME}/OpenFOAM/OpenFOAM-1.2/lib/linuxGcc40pt/libPVFoamReader.so
if yours is not there, you should try a reinstall of the OpenFOAM binary pack for linux.
Old   November 25, 2005, 13:44
Default Strange, suddenly I also got m
unoder
Strange, suddenly I also got myself a problem with paraview/parafoam. I has worked for 2 months and when I start it now it says:
/home/martin/OpenFOAM/OpenFOAM-1.2/bin/paraFoam: line 57: 8710 Segmentation fault paraview paraFoam.pvs
This is really strange. I restarted and still got this problem with all my cases. Perhaps reinstallation is the only way out now...
Old   November 25, 2005, 16:37
Default 1. Maybe there is something in
Mattijs Janssens
mattijs is on a distinguished road
1. Maybe there is something in your ~/.Paraview* files it is not happy about?
2. Unsetenv PV_INTERFACE_PATH and try running paraview instead of paraFoam.
mattijs is offline   Reply With Quote
Old   November 26, 2005, 17:09
Default Hey, thanks a lot Mattijs,
unoder
I just did a:
martin@linux:~> rm .ParaViewlmk
martin@linux:~> rm .ParaViewrc
And now everything seems to work again. I have absolutely no idea what might have screwed those files up, but the important thing is that now it works again and it was easy to fix :-)
Old   December 20, 2005, 19:32
Default Dear Martin Jørgensen: I ha
Guoxiang
liugx212 is on a distinguished road
I have the same question as you. But I really do not know what you said "martin@linux:~> rm .ParaViewlmk
martin@linux:~> rm .ParaViewrc ".
Could you please give more help?
Thank you very much.
Xiang
liugx212 is offline   Reply With Quote
Old   December 25, 2005, 13:20
Default Those are hidden files. Theref
  #11
unoder
Those are hidden files. Therefore you wont see them unless you write "ls -a". As I remember it, they were placed in your home directory. So you should be able to type:
1) cd ~ (or I think just "cd" would do the same)
2) rm .ParaViewlmk
3) rm .ParaViewrc
And then everything worked, at least for me.
ParaView Execute problem insta OpenFOAM Installation 2 June 9, 2014 02:37
[General] Problem in using paraview meballav ParaView 11 October 12, 2012 16:03
[OpenFOAM] Installation problem with ParaView 3.8.0 on openSUSE 11.2 aero_ ParaView 14 August 2, 2010 18:13
Yet another Paraview problem gascortado OpenFOAM 5 February 21, 2010 06:39
[OpenFOAM] Problem with Colors in ParaView sven ParaView 1 May 31, 2009 08:13
