Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Problem with parafoam on ubuntu 9.10 machine
Old   December 25, 2009, 23:12
Default Problem with parafoam on ubuntu 9.10 machine
Nabeel
nabeels is on a distinguished road
Hello Foamers
I have installed openFOAM 1.6 on a machine running with ubuntu 9.10 with no compilation problems. As an example, when the cavity problem was run, I was able to see the progress of the solution till it ended successfully.
Unfortunately, when I came to view the results, nothing appeared in paraview when parafoam was executed . I was able to see the meshed domain (before calling the solver icofoam) but not the results. The version of paraview used is 3.6.1. I used vtk files to load them into paraview and they failed due the following error:
p, li { white-space: pre-wrap; } ERROR: In /home/dm2/henry/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/VTK/IO/vtkXMLParser.cxx, line 484
vtkPVXMLParser (0x39c02e0): Error parsing XML in stream at line 1, column 1, byte index 1: not well-formed (invalid token)
Root does not exist. Either state file could not be opened or it does not contain valid xml
vtkPVXMLParser (0x2f5cc40): Error parsing XML in stream at line 1, column 0, byte index 0: not well-formed (invalid token)
Any idea how to solve this problem with paraview?
nabeels is offline   Reply With Quote
[OpenFOAM.org] problem with instaling openfoam-2.0.0 on ubuntu 18.04 alireza.sh OpenFOAM Installation 11 November 22, 2018 11:09
paraFoam command no longer working after upgrading to Ubuntu 13.04 c_dowd OpenFOAM Installation 9 June 24, 2013 08:28
Installation problem on Ubuntu gara1988 OpenFOAM Installation 1 October 15, 2012 10:00
HP Elite i7 64bit machine installation problem ahlo7 OpenFOAM Installation 1 March 1, 2011 17:36
[OpenFOAM] Problem with paraFoam (ubuntu 9.04) peb ParaView 4 August 24, 2009 09:50
