[OpenFOAM] ParaFoam instalation in OpenFoam 1.5 dev |
July 22, 2010, 15:42 |
Hi foamers,
Is it possible to install and use paraview/parafoam in OpenFoam 15.dev. I am trying to correct the script that comes with OpenFoam 1.5 dev, using as a base the script of OpenFoam 1.6, but it is costing me a lot. Can anyone help out, or, is it easier to install openFoam 1.7 in the same account and change the environmemt variables in .bashrc whenever desirable. Regards, Titio |
July 23, 2010, 06:34 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Titio,
I have pretty much no experience with the -dev project, but as far as I can tell, it should be as simple as in the official OpenFOAM. You have to edit the file "OpenFOAM-1.5-dev/etc/apps/paraview3/bashrc" and tweak it to suit your needs and make it point to your installed ParaView! Or you can leave that file intact and try to use the official ParaView version 3.8.0, which now comes with its own working foam reader, thankfully to Takuya's plugin . I've posted on my blog on this forum on how to do this: Using the official pre-built ParaView 3.8.0 version with OpenFOAM... Hopefully it will work with the -dev project as well! Best regards, Bruno
July 24, 2010, 23:24 |
Sourcing 1.5 dev seems to disrupt the operational of paraview.
I source openfoam in a shell each time I run it (no in my user .bashrc file) and run foamToVTK. I then open up paraview from a different shell and locate the files manually, or use paraDisplay(my own little code snipit). http://www.cfd-online.com/Forums/ope...-parafoam.html Im in the process of getting paraDisplay to work with 1.5dev in the same shell. I will post it when I write it. |
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology | wyldckat | OpenFOAM | 17 | November 10, 2017 15:54 |
OpenFOAM v3.0+ ?? | SBusch | OpenFOAM | 22 | December 26, 2016 14:24 |
[OpenFOAM.org] Mac OS X 10.11 and OpenFOAM 3.0: Error when running ParaFoam with "command not found" | hua | OpenFOAM Installation | 9 | February 10, 2016 23:45 |
[General] Using Python in Openfoam in-built paraFoam (paraView 3.8.0) | Man Yue | ParaView | 6 | November 30, 2012 06:57 |
OpenFOAM Version 1.5 Released | OpenFOAM discussion board administrator | OpenFOAM Announcements from ESI-OpenCFD | 0 | July 14, 2008 18:22 |
