Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
how to rerun when compressed is on?
Like Tree2Likes
  • 2 Post By wyldckat
Old   June 9, 2013, 05:51
Default how to rerun when compressed is on?
immortality's Avatar
Ehsan
immortality is on a distinguished road
I have set
writeCompression on;
and stop the run.now it gives an error:
Create time
Create mesh for time = 4e-06
Reading thermophysical properties
Selecting thermodynamics package
type            hePsiThermo;
mixture         pureMixture;
transport       sutherland;
thermo          janaf;
equationOfState perfectGas;
specie          specie;
energy          sensibleEnthalpy;
[0]
[0]
[0] [2] --> FOAM FATAL IO ERROR:
[0] cannot find file
[0]
[0] file: /home/ehsan/Desktop/Central/Turbulent_WR/low-Re/turbulent_lR700*50/processor0/4e-06/p at line 0.
[0]
[0]     From function regIOobject::readStream()
[0]     in file db/regIOobject/regIOobjectRead.C at line 73.
[0]
FOAM parallel run exiting
[0]
[2]
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
[2] cannot find file
[2]
[2] file: /home/ehsan/Desktop/Central/Turbulent_WR/low-Re/turbulent_lR700*50/processor2/4e-06/p at line 0.
[2]
[2]     From function regIOobject::readStream()
[2]     in file db/regIOobject/regIOobjectRead.C at line 73.
[2]
[2]
[3]
[3]
[3] [1] --> FOAM FATAL IO ERROR:
[3] cannot find file
[3]
[3] file: /home/ehsan/Desktop/Central/Turbulent_WR/low-Re/turbulent_lR700*50/processor3/4e-06/p at line 0.
[3]
[3]     From function regIOobject::readStream()
[3]     in file db/regIOobject/regIOobjectRead.C at line 73.
[3]
[3]
mpirun has exited due to process rank 0 with PID 3414 on
node Ehsan-com exiting without calling "finalize". This may
have caused other processes in the application to be
terminated by signals sent by mpirun (as reported here).
[Ehsan-com:03412] 2 more processes have sent help message help-mpi-api.txt / mpi-abort
[Ehsan-com:03412] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
Killing PID 3408
 PyFoam WARNING on line 232 of file /usr/local/lib/python2.7/dist-packages/PyFoam/Execution/FoamThread.py : Process 3408 was already dead
how can overcome this issue without decompressing individual files.
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   June 9, 2013, 07:04
Retired Super Moderator
Bruno Santos
Hi Ehsan,
Does either one of the following files exist?
/home/ehsan/Desktop/Central/Turbulent_WR/low-Re/turbulent_lR700*50/processor0/4e-06/p.gz
If neither one of them exist, then it's possible that you stopped the simulation at a bad point in time, exactly when the solver was writing the fields and you made it stop.
The safe way to stop a running case is to edit the file "system/controlDict" and change the "stopAt" control to either "writeNow" or "nextWrite", which will ensure that the time snapshot is properly saved before ending. For more information: http://www.openfoam.org/docs/user/controlDict.php
Best regards,
Bruno
immortality and JR22 like this.
Error writing compressed file during auto save mzalzala FLUENT 32 April 20, 2020 08:58
Interblending two Eulerian fluids using compressed air JHaas OpenFOAM Running, Solving & CFD 0 November 3, 2011 02:50
Compressed Nitrigen go4kpo Main CFD Forum 0 November 19, 2005 05:10
rerun with same flow field, different fluid props Tim Phoenics 0 March 3, 2004 14:51
Working with compressed case and data files Darrell Anthony Egarr FLUENT 0 December 15, 2002 07:05
