June 9, 2013, 05:51 |
how to rerun when compressed is on?
Ehsan
Rep Power: 26 |
I have set
writeCompression on; Code:
Create time Create mesh for time = 4e-06 Reading thermophysical properties Selecting thermodynamics package { type hePsiThermo; mixture pureMixture; transport sutherland; thermo janaf; equationOfState perfectGas; specie specie; energy sensibleEnthalpy; } [0] [0] [0] [2] --> FOAM FATAL IO ERROR: [0] cannot find file [0] [0] file: /home/ehsan/Desktop/Central/Turbulent_WR/low-Re/turbulent_lR700*50/processor0/4e-06/p at line 0. [0] [0] From function regIOobject::readStream() [0] in file db/regIOobject/regIOobjectRead.C at line 73. [0] FOAM parallel run exiting [0] [2] -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. -------------------------------------------------------------------------- [2] --> FOAM FATAL IO ERROR: [2] cannot find file [2] [2] file: /home/ehsan/Desktop/Central/Turbulent_WR/low-Re/turbulent_lR700*50/processor2/4e-06/p at line 0. [2] [2] From function regIOobject::readStream() [2] in file db/regIOobject/regIOobjectRead.C at line 73. [2] FOAM parallel run exiting [2] [3] [3] [3] [1] --> FOAM FATAL IO ERROR: [3] cannot find file [3] [3] file: /home/ehsan/Desktop/Central/Turbulent_WR/low-Re/turbulent_lR700*50/processor3/4e-06/p at line 0. [3] [3] From function regIOobject::readStream() [3] in file db/regIOobject/regIOobjectRead.C at line 73. [3] FOAM parallel run exiting [3] -------------------------------------------------------------------------- mpirun has exited due to process rank 0 with PID 3414 on node Ehsan-com exiting without calling "finalize". This may have caused other processes in the application to be terminated by signals sent by mpirun (as reported here). -------------------------------------------------------------------------- [Ehsan-com:03412] 2 more processes have sent help message help-mpi-api.txt / mpi-abort [Ehsan-com:03412] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages Killing PID 3408 PyFoam WARNING on line 232 of file /usr/local/lib/python2.7/dist-packages/PyFoam/Execution/FoamThread.py : Process 3408 was already dead
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King. To Be or Not To Be,Thats the Question! The Only Stupid Question Is the One that Goes Unasked. |
June 9, 2013, 07:04 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi Ehsan,
Does either one of the following files exist? Code:
/home/ehsan/Desktop/Central/Turbulent_WR/low-Re/turbulent_lR700*50/processor0/4e-06/p /home/ehsan/Desktop/Central/Turbulent_WR/low-Re/turbulent_lR700*50/processor0/4e-06/p.gz The safe way to stop a running case is to edit the file "system/controlDict" and change the "stopAt" control to either "writeNow" or "nextWrite", which will ensure that the time snapshot is properly saved before ending. For more information: http://www.openfoam.org/docs/user/controlDict.php Best regards, Bruno
Error writing compressed file during auto save | mzalzala | FLUENT | 32 | April 20, 2020 08:58 |
Interblending two Eulerian fluids using compressed air | JHaas | OpenFOAM Running, Solving & CFD | 0 | November 3, 2011 02:50 |
Compressed Nitrigen | go4kpo | Main CFD Forum | 0 | November 19, 2005 05:10 |
rerun with same flow field, different fluid props | Tim | Phoenics | 0 | March 3, 2004 14:51 |
Working with compressed case and data files | Darrell Anthony Egarr | FLUENT | 0 | December 15, 2002 07:05 |
