Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
displacement output from elasticNonLinTLSolidFoam
Old   May 5, 2016, 13:38
Default displacement output from elasticNonLinTLSolidFoam
Terry H is on a distinguished road
I'm using elasticNonLinTLSolidFoam, and would like to be able to pair the vertex (?) coordinates output in constant/polyMesh---in particular, the "points" text file generated by blockMesh---to the displacement field output from elasticNonLinTLSolidFoam at these vertices (that is, the text file "U" generated by elasticNonLinTLSolidFoam for each time step).
What is the ordering that associates a point (x,y,z) with a displacement (Ux,Uy,Uz)? In other words: what coordinate (x,y,z) in the "points" text file file corresponds to the displacement (Ux,Uy,Uz) in the "U" text file file?
Thank you in advance for any pointers or guidance you can offer about this!
Terry H is offline   Reply With Quote
[swak4Foam] outputTime in Swak function immortality OpenFOAM Community Contributions 20 October 6, 2022 12:08
snappyhexmesh remove blockmesh geometry philipp1 OpenFOAM Running, Solving & CFD 2 December 12, 2014 10:58
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 09:53
writing execFlowFunctionObjects immortality OpenFOAM Post-Processing 30 September 15, 2013 06:16
RNG diverged during the analysis the flow over a multi element airfoil, why? s.m OpenFOAM Running, Solving & CFD 0 August 5, 2013 08:39
