Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
yPlus for cavitatingFoam
Like Tree1Likes
  • 1 Post By Lorena2fdez
Old   June 8, 2016, 05:40
Default yPlus for cavitatingFoam
Quang Le Dang
SPH_CFD is on a distinguished road
Dear all
I am running a case using cavitatingFoam. However, I have a problem when I want to check yPlus. It is always "command not found". Do you know some ways to get this value?
Thank you in advance.
SPH_CFD is offline   Reply With Quote
Old   June 8, 2016, 07:07
Lorena Fernández Fernández
Lorena2fdez is on a distinguished road
Originally Posted by SPH_CFD View Post
Dear all
You need to use the comands "yPlusRAS" or "yPlusLES". Use "yPlusRAS --help" for their options. Look at simulationType in turbulenceProperties for know which use.
Best regards,
Lorena
Lorena2fdez is offline   Reply With Quote
Old   June 8, 2016, 09:54
Quang Le Dang
Best regards,
Lorena
Thank you for your answer. However, I cannot perform that command and get "command not found". I do not know that yPlusRas is possible for mixture model in OF or not?
I see here for openFOAM 1.5. They say that yPlusRAS only exist for singlephase.
http://www.cfd-online.com/Forums/ope...-yplusras.html
Is it true?
Old   June 8, 2016, 11:10
Is it true?
If you loaded correctly OpenFOAM your wouldn't have the problem "command not found". I use OpenFOAM-2.3.0 and the comand "yPlusRAS" is recognized.
Generally there's a problem with the function yPlusRAS. It say that don't read the value of nu. You need to change the constant/transportProperties and write in the initial lines the value of nu. Remember restart the file for run the case. For the tutorial example of cavitatingFoam:
|  \\    /   O peration     | Version:  2.3.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      transportProperties;
mul             mul [ 1 -1 -1 0 0 ] 0.0065;
muv             muv [ 1 -1 -1 0 0 ] 5.953e-06;
## Only for yPlusRAS ##
    transportModel  Newtonian;
    nu              nu [ 0 2 -1 0 0 0 0 ] 7.831e-06;
phases (vapour water);
water
    rho             rho [ 1 -3 0 0 0 0 0 ] 830;
    CrossPowerLawCoeffs
        nu0             nu0 [ 0 2 -1 0 0 0 0 ] -999;
        nuInf           nuInf [ 0 2 -1 0 0 0 0 ] -999;
        m               m [ 0 0 1 0 0 0 0 ] -999;
        n               n [ 0 0 0 0 0 0 0 ] -999;
    BirdCarreauCoeffs
        k               k [ 0 0 1 0 0 0 0 ] -999;
vapour
    nu              nu [ 0 2 -1 0 0 0 0 ] 4.252e-05;
    rho             rho [ 1 -3 0 0 0 0 0 ] 0.14;
    CrossPowerLawCoeffs
    BirdCarreauCoeffs
The idea of the problem of yPlusRAS is like the function don't read transportProperties after "phases (vapour water);" and it doesn't get the respective values.
Best regards,
Lorena
caohuali likes this.
Old   June 9, 2016, 12:14
Quang Le Dang
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
water
    CrossPowerLawCoeffs
    BirdCarreauCoeffs
vapour
    CrossPowerLawCoeffs
    BirdCarreauCoeffs
Best regards,
Lorena
Hi Lorena. Thank you so much !!! it works !!!
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 02:36
Solver Yplus of Automatic wall treatment justjhy CFX 2 May 4, 2013 07:19
How to calculate Y+( Yplus) mohammad Main CFD Forum 3 January 11, 2011 23:23
which yplus (SST) sanchezz CFX 17 January 11, 2010 04:45
heat transfer coefficients with "bad" yplus Andrew Main CFD Forum 4 April 8, 1999 04:43
