Power draw of a mixer
Old   April 6, 2010, 04:33
Default Power draw of a mixer
Andreas
erklaerbaer is on a distinguished road
my goal is to evaluate the power draw of a mixer (mixer3D) via the integration of the forces acting on the moving or non-moving parts over the relevant patch.
I am an absolute Newbie in OpenFOAM and threw together some Code from the wallShearStree, wallGradU, patchIntegrate utilities and some things i read in the forum.
I try to get the velocity gradient with
IOobject Uheader
            "U",
            runTime.timeName(),
            mesh,
            IOobject::MUST_READ
Info<< "    Reading U" << endl;
volVectorField U(Uheader, mesh);
Info<< "    Calculating wallGradU" << endl;
volVectorField wallGradU
        IOobject
                    "wallGradU",
                    runTime.timeName(),
                    mesh,
                    IOobject::NO_READ,
                    IOobject::AUTO_WRITE
        mesh,
               dimensionedVector
                    "wallGradU",
                    U.dimensions()/dimLength,
                    vector::zero
    forAll(wallGradU.boundaryField(), patchi)
                wallGradU.boundaryField()[patchi] =
                    U.boundaryField()[patchi].snGrad();
and to calculate the sheer rate with
Info<< "    Calculating Stress" << endl;
        volScalarField wallForces
            IOobject
                "wallForces",
                runTime.timeName(),
                mesh,
                IOobject::NO_READ,
            //dynVis*sqrt(sqr(wallGradU.component(vector::X)) + sqr(wallGradU.component(vector::Y))+sqr(wallGradU.component(vector::Z)))
         dynVis*mag(wallGradU)
       wallForces.write();
If i am correct the value for tau is at this point calculated and stored in wallForces. Am i right?
Now i want to integrate tau over the faces of the patch, or not?
IOobject fieldHeader
            "wallForces",
            runTime.timeName(),
            mesh,
            IOobject::MUST_READ
        // Check field exists
        if (fieldHeader.headerOk())
            mesh.readUpdate();
            label patchi = mesh.boundaryMesh().findPatchID(patchName);
            if (patchi < 0)
                FatalError
                    << "Unable to find patch " << patchName << nl
                    << exit(FatalError);
const polyPatch& cPatch = mesh.boundaryMesh()[patchi];
const surfaceScalarField& magSf = mesh.magSf();
    scalar Power = 0;
    volScalarField field(fieldHeader, mesh);
    forAll(cPatch, facei)
        Power += magSf.boundaryField()[patchi][facei] * field.boundaryField()[patchi][facei];
    Info<< "    Power = " << Power << endl;
Now the biggest Problem is that the calculation is not finished because the Integration of tau over the patch area gives me a force but not Energy or even Power.
Can someone give me a hint how i bring this "element" into my code? Or point me to a source where i can find the formula to calcualte the power draw via this method.
Thanks in advance.
Andi
erklaerbaer is offline   Reply With Quote
Old   April 6, 2010, 14:51
Holger Marschall
holger_marschall is on a distinguished road
Send a message via Skype™ to holger_marschall
Hi Andi,
welcome to this board...
You might want to have a look at
Handbook of Industrial Mixing (page 314)
Published Online: 30 Jan 2004
http://www3.interscience.wiley.com/c...home/107583875
Editor(s): Edward L. Paul, Victor A. Atiemo-Obeng, Suzanne M. Kresta
Print ISBN: 9780471269199 Online ISBN: 9780471451457
DOI: 10.1002/0471451452
"The power delivered to the fluid is the product of the impeller speed, 2πN, in rad/s, and torque, τ, which is obtained by integration of the pressure on the impeller blade: P = 2πNτ"
and/or
CFD Simulation of Flow in a Baffled Stirred Tank
GL Lane, PTL Koh
Chemeca 97, 25th Australian and New Zealand Chemical Engineering Conference, Rotorua, NZ, September/October 1997, Paper FL2B, 9 pp
http://www.cfd.com.au/cfd_conf97/papers/lan035.pdf
This should give a first approximate number (if one neglects the shear). Hope this helps.
best,
Holger Marschall
web: http://www.holger-marschall.info
mail: holgermarschall@yahoo.de
holger_marschall is offline   Reply With Quote
Old   April 7, 2010, 15:56
Andreas
Thank you .
Unfortunately I am stuck at the next phase. But now it is more a problem of the OpenFOAM Programming syntax i dont really geht.
I try to get torque by summing up the
Area of every Face * Pressure on that face * Distance to the Center (= lever arm)
My Syntax for that is
##Read the calculated pressure from the corresponding file
IOobject pressureHeader
            "p",
            runTime.timeName(),
            mesh,
            IOobject::MUST_READ
volScalarField pressure(pressureHeader, mesh);
#Find IF for the Patch, in that case the Impeller
#I guess this reads the areasizes
        Torque +=
mag(pressure.boundaryField()[patchi][facei])*
Foam::sqrt(
     sqr(pressure.mesh().boundary()[patchi].Cf()[facei][0])+
     sqr(pressure.mesh().boundary()[patchi].Cf()[facei][1])
magSf.boundaryField()[patchi][facei] = area of the face?
mag(pressure.boundaryField()[patchi][facei]) = pressure on that face?
pressure.mesh().boundary()[patchi].Cf()[facei][0] = The x-Coordinate of the Center of the face?
The results i get are to low by arround 1E-2 so i guess i have a missunderstanding in the Syntax of OpenFOAM, if someone could lighten me up i would be very grateful.
Andi
Old   April 8, 2010, 05:38
Andreas
If somebody is interested:
I wrote a little Tool for turbulent flows which calculates the powerdraw from the Epsilon-Term,
P = rho * Integral(Epsilon dV)
andi
Old   June 14, 2010, 15:43
maximeg is on a distinguished road
Hi!
I'm a beginner at OpenFOAM and I'd like some help if possible.
I have to calculate the circulation in a vortex. My code is as follows:
#include "calc.H"
#include "fvc.H"
void Foam::calc(const argList& args, const Time& runTime, const fvMesh& mesh)
    volScalarField magVorticity        // Imports the results of the vorticity of the vortex
        IOobject
            "magVorticity",
            runTime.timeName(),
            mesh,
            IOobject::MUST_READ,
        mesh
    scalar circulation = 0.0;
    scalar r = 0.0;
    const volScalarField& magSf = mesh.magSf();
    forAll(magVorticity, cellI)
        if (distance < r[cellI])        // If the radius (distance) stays lower than the critical radius (r)...
            circulation += magSf.magVorticity[cellI];     // ...calculation of the circulation.
The error message I get in the terminal is as follows:
SOURCE=MaxVorCirc.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-40 -I/usr/local/OpenFOAM/OpenFOAM-1.6/src/postProcessing/postCalc -I/usr/local/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude -IlnInclude -I. -I/usr/local/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/usr/local/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/MaxVorCirc.o
MaxVorCirc.C: In function ‘void Foam::calc(const Foam::argList&, const Foam::Time&, const Foam::fvMesh&)’:
MaxVorCirc.C:89: error: invalid types ‘Foam::scalar[Foam::label]’ for array subscript
MaxVorCirc.C:94: error: ‘magSf’ was not declared in this scope
make: *** [Make/linux64GccDPOpt/MaxVorCirc.o] Error 1
Any help would be very appreciated.
Thank you in advance!
Maxime
maximeg is offline   Reply With Quote
Non-Newtonian Power Law for Viscosity John FLUENT 16 September 12, 2015 06:18
Wind Power Frank Grassi FLUENT 0 October 12, 2007 11:20
power curve of windmills with CFD sayid FLUENT 2 March 28, 2007 09:55
Non newtonian power law model in pipe annulus Poly FLUENT 0 March 24, 2005 15:12
Intl Conf Computational Methods in Fluid Power Jacek Stecki Main CFD Forum 0 November 10, 2002 05:49
