airfoil in Openfoam-beginer
Like Tree1Likes
  • 1 Post By nimasam
Old   May 16, 2013, 10:10
Default airfoil in Openfoam-beginer
hamed noordoost
hamednoordoost@yahoo.com is on a distinguished road
hi
I want to compare answer of fluent and Open foam on an Airfoil with laminar, strady flow with constant velocity an Re=2000.
I solve the Fluent one But can't Open mesh (same as one use foe fluent) in Open foam. Open foam give me error on attached Picture
What is the Problem?
hamednoordoost@yahoo.com is offline   Reply With Quote
Old   May 16, 2013, 12:15
Nima Samkhaniani
nimasam is on a distinguished road
dear hamed
several suggestions:
1- first try to install a distribution of Linux ( Ubuntu is preferred)
if you can not get rid of windows , you can use VMware or virtualbox
2- install OpenFoam on your linux
because OpenFOAM in windows is like a pain in the ass
However your problem is some where else
you used your command wrongly! that command needs that you enter the .msh file name after the command
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
OpenFOAM 1.6.x, 1.7.0 and 1.7.x are not fully prepared to work with gcc-4.5.x wyldckat OpenFOAM Bugs 18 October 21, 2010 05:51
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 06:25
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 14:25
Airfoil boundary condition Frank Main CFD Forum 1 April 21, 2008 18:36
