August 14, 2013, 13:35 |
renumberMesh and cyclic BC's
Hi everyone,
i hope someone has some experience with the following: I have a rotationally cyclic mesh, which i import from from Fluent format, and use createPatch to recreate the cyclics etc. However, i have just discovered renumberMesh to reduce bandwidth, and so gave this a try - how, it seems to mess up the face numbering on the cyclic faces - and then i get a face area mismatch warning when i try to run the solver. Does anyone know how / if it is possible to use renumberMesh, without destroying the face numbering sequence on cyclic faces, or what i need to do to re-recreate the cyclic faces so they are correctly matched with their opposite faces? best regards jon |
November 5, 2013, 18:49 |
Frank Ubber
Rep Power: 12 |
I know this post is old, but did you try to run "createPatch" again after renumbering your mesh? That might fix mismatching faces.
November 6, 2013, 02:48 |
hi Frank,
yes, i tried pretty much all the permutations, including renumberMesh after the renumbering, but had no luck. The mismatch warning you get which says something like: "there is a difference in area between face x and face y of xx.xxx% etc" popped up and i couldnt get past that if i remember correctly. I tried reducing the tolerances as is normally suggested, but no luck. i have put it aside for the time being! cheers for the reply jonathan |
November 23, 2013, 05:25 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
This looks to me that this was a bug in an older version of OpenFOAM. I expect the latest 2.2.2 and 2.2.x to no longer have this problem, due to this bug report: http://www.openfoam.org/mantisbt/view.php?id=1086 Nonetheless, if a simple test case could be provided, I can give it a try and ascertain if this is indeed a bug or not, so that it can be reported on the aforementioned bug tracker! Best regards, Bruno
createpatch, cyclics, error, renumbermesh |
[snappyHexMesh] Can't couple front & back faces in cyclic BC after snapping in SHM | hakonbar | OpenFOAM Meshing & Mesh Conversion | 4 | December 8, 2013 16:50 |
[snappyHexMesh] Solution Snappy Hex 2D Msh with Surface Layers and cyclic bc for symmetric geometry | flexi182 | OpenFOAM Meshing & Mesh Conversion | 0 | May 24, 2013 08:38 |
cyclic BC - createPatch | AirS | OpenFOAM | 7 | November 12, 2009 10:04 |
