September 29, 2016, 05:37 |
Leaking snappyHexMesh
carno
Rep Power: 17 |
Dear All,
I am trying to mesh an enclosure. I am using a closed volume for volume meshing and extracted surfaces for creating patches. There is 1 inlet and 1 outlet. The problem is, if I mesh the volume without surface STLs as patches it meshes perfectly. As soon as I use extracted STL surfaces as patches it leaks, the same volume STL. I am attaching the two cases pictures. Code:
geometry { fixed.stl { type triSurfaceMesh; name fixed; regions { CFD_VOLUME_08 // Named region in the STL file { name wallsassy; // User-defined patch name } } } inlet.stl { type triSurfaceMesh; name inlet; } outlet.stl { type triSurfaceMesh; name outlet; } /* canopy.stl { type triSurfaceMesh; name canopy; }*/ Kindly help.. |
[CAD formats] Creating waterproof STL using snappyHexMesh or salome | Tobi | OpenFOAM Meshing & Mesh Conversion | 58 | May 13, 2020 06:01 |
[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. | jasv | OpenFOAM Meshing & Mesh Conversion | 4 | May 10, 2016 02:55 |
[snappyHexMesh] snappyhexmesh doesn't creat mesh in parallel issue? | klausb | OpenFOAM Meshing & Mesh Conversion | 1 | March 7, 2015 11:55 |
[snappyHexMesh] snappyHexMesh and blockMesh for internal flow (leaking geometry?) | vaina74 | OpenFOAM Meshing & Mesh Conversion | 10 | November 20, 2014 09:14 |
[snappyHexMesh] stitchMesh and snappyHexMesh | gdbaldw | OpenFOAM Meshing & Mesh Conversion | 0 | December 23, 2009 02:09 |
