boundary condition for zerothickness surface :(
Old   April 15, 2015, 08:05
Default boundary condition for zerothickness surface :(
Naresh Yathuru
Naresh yathuru is on a distinguished road
Hi Foamers,
sorry for restarting the thread again. I need to implement baffles in my case. i have some basic question can some one please help me.
I m having a zero thickness surface in my geometry and i have read a lot of posts regarding how to implement baffles which helped me create a mesh with baffles in snappyHexMesh. (thanks to the changes in snappyhexmesh)
code in snappyHexmesh, refinementsurfaces
table
        level (2 2);
        faceZone table;
        // Create baffles for all faces on the surface
        faceType baffle;
        cellZone table;
        cellZoneInside inside;
In paraview i have two patches created, a master and a slave. so far its good.
and i have checked in the polymesh/boundary folder two boundaries are created of type wall.
table
        type            wall;
        inGroups        1(wall);
        nFaces          588;
        startFace       653617;
    table_slave
        type            wall;
        inGroups        1(wall);
        nFaces          588;
        startFace       654205;
now my questions are
1.How can i define B.C to these patches like U,P,K,epsilon
2. do i have to make a folder for "createbafflesDict" to specify boundary conditions or can i specify B.C like for other patches?
3. last and much important question is can i spesify different boundary conditions for the master and slave patch similar to twosidedwall in fluent?
I have looked in to couple of tutorials but could not get a clear answer.
I m using OF 2.3.0
I m banging my head on the wall. could someone please help me.
Regards,
Naresh
[ Moderator note: Moved post from http://www.cfd-online.com/Forums/ope...nal-faces.html ]
Naresh yathuru is offline   Reply With Quote
Old   April 28, 2015, 12:58
Naresh Yathuru
Hi Foamers,
I have a case with zero thickness sucface inside my domain. I innitially thought that i need to have createBafflesDict then i came to know that i can create baffles using STL files in the snappyHexMesh. thanks to SHM.
Now i m kind of stuck trying to set booundary conditions for the master and slave patches ,where to specify the B.C?
can somebody please help me.
// Which of the steps to run
castellatedMesh true;    // make basic mesh ?
snap            true;    // decide to snap back to surface ?
addLayers       false;   // decide to add viscous layers ?
geometry // Load in STL files here
    /*baffle
        type searchablePlate;
        origin (2.4 1.8 0.8);
        span (1.2 2.7 0.8);
         regions
            region0
               name  baffle;
    inlet.stl {type triSurfaceMesh; name inlet;}
    outlet.stl {type triSurfaceMesh; name outlet;}
    heater.stl {type triSurfaceMesh; name heater;}
    roomwall.stl {type triSurfaceMesh; name roomwall;}
        roof.stl {type triSurfaceMesh; name roof;}
        floor.stl {type triSurfaceMesh; name floor;}
        window.stl {type triSurfaceMesh; name window;}
        table.stl {type triSurfaceMesh; name table;}
        man1.stl {type triSurfaceMesh; name man1;}
        man2new.stl {type triSurfaceMesh; name man2new;}
    //fullgeomnew.stl {type triSurfaceMesh; name fullgeomnew;}
        //mergedwithouttable.stl {type triSurfaceMesh; name mergedwithouttable;}
    //refinementBox {type searchableBox; min (-2 -2 6); max (7 5 -2);}
castellatedMeshControls
    maxLocalCells 500000;  //max cells per CPU core
    maxGlobalCells 4000000; //max cells to use before mesh deletion step
    minRefinementCells 10;  //was 0 - zero means no bad cells are allowed during refinement stages
    maxLoadUnbalance 0.10;
    nCellsBetweenLevels 3;  // expansion factor between each high & low refinement zone
    // Explicit feature edge refinement
    features // taken from STL from each .eMesh file created by "SurfaceFeatureExtract" command
       {file "inlet.eMesh"; level 5;}
        {file "outlet.eMesh"; level 3;}
        {file "roomwall.eMesh"; level 3;}
        {file "heater.eMesh"; level 2;}
        {file "roof.eMesh"; level 1;}
        {file "floor.eMesh"; level 2;}
        {file "window.eMesh"; level 3;}
        {file "table.eMesh"; level 3;}
        {file "man1.eMesh"; level 2;}
        {file "man2new.eMesh"; level 3;}
        //{file "mergedwithouttable.eMesh"; level 3;}
    // Surface based refinement
    refinementSurfaces // Surface-wise min and max refinement level
    inlet {
        level (5 5);//faceZone inlet;cellZone inlet;cellZoneInside inside;
        } // was 0 0
        outlet {
         level (3 3);//faceZone outlet;cellZone outlet;cellZoneInside inside;
    roomwall {
        level (3 3);//faceZone roomwall;cellZone roomwall;cellZoneInside inside;
        }  //was 3 3
    heater {
        level (2 2);//faceZone heater;cellZone heater;cellZoneInside inside;
        } // was 4 4
        roof {
        level (2 2);///faceZone roof;cellZone roof;cellZoneInside inside;
        floor {
        level (2 2);//faceZone floor;cellZone floor;cellZoneInside inside;
        window {
        level (3 3);//faceZone window;cellZone window;cellZoneInside inside;
        //table {
        //level (0 0);//faceZone table;cellZone table;cellZoneInside inside;
        man1 {
        level (3 3);//faceZone man1;cellZone man1;cellZoneInside inside;
        man2new {
        level (3 3);//faceZone  man2;cellZone man2;cellZoneInside inside;
        //baffle {level (3 3);}
        table
        level (3 3);
        faceZone table;
        faceType baffle;
        cellZone table;
    resolveFeatureAngle 30;  // (before 80) .Resolve sharp angles // Default 30
    //refinementRegions        // In descending levels of fine-ness
    //{fullgeomnew //{mode inside;levels ((0.3 3));}}      //error: shell mergedtest is suitable for inside mode.
     //{mode distance; levels ((0.01 4) (0.03 3) (0.1 2));}} // was ((0.001 4) (0.003 3) (0.01 2))
     //when i tried like this
    refinementRegions{}
     //the whole geometry is meshed and the cell are not removed.*/
    locationInMesh (1 1 1);  //to decide which side of mesh to keep **
    allowFreeStandingZoneFaces true; // before true
// Settings for the snapping.
snapControls
    nSmoothPatch 5;// before 3
    tolerance 1.0; // before 2
    nSolveIter 50;// before 30
    nRelaxIter 10; //before 5
    nFeatureSnapIter 25; // default is 10
// New settings from openfoam 2.2 onwards for SHMesh
implicitFeatureSnap false; // default is false - detects without doing surfaceFeatureExtract
explicitFeatureSnap true; // default is true
multiRegionFeatureSnap true; // deafault is false - detects features between multiple surfaces
I m using buoyantBoussinessqsimpleFoam solver. As a first step i m intended to implement a no-slip U(0,0,0) B.c
I have looked into some tutorials but each tutorials has a different style of implementing the baffles. so i could not able to find it myself.
I m desperate for help.
Thank you ,
regards,
Naresh
Old   April 30, 2015, 12:40
Retired Super Moderator
Bruno Santos
Quick answer: Study the tutorial cases "compressible/rhoPimpleDyMFoam/annularThermalMixer" and "incompressible/pimpleFoam/TJunctionFan".
Hints:
  • The first one demonstrates how to create the baffles.
  • The second one demonstrates how to define the boundary conditions while it's creating the baffles.
Old   May 4, 2015, 04:26
Naresh Yathuru
Dear Bruno,
Thank you for your reply. I will check it out.
Regards,
Naresh Yathuru
Old   September 19, 2016, 04:35
Naresh Yathuru
Hello foamers,
I took me a while to update this post. I was not successful
so I tried a very simple geometry of a box with a zero thickness surface inside. i created the geometry in salome.Exported geometry as stl files and meshed in snappyHexMesh. I used the "facetype baffles" in snappy hex mesh to create baffle.
I have the following questions:
1. After meshing it shows the master and slave boundary in polymesh/boundary files. how to set boundary conditions for these surfaces in 0 folder?
Am I missing something. There is no tutorials for the method where snappyhexmesh is used to create baffles. I have tried the tutorials Tjunctionfan and thermal baffles tutorials but they use createbafflesDict. but I want to generate baffles for the geometry stl file i created in Salome.
When I triedto use my stl files in createbafflesdict there was snapping problem. I created stairscasestep mesh.
Could someone through some light. I m stuck at this point.
I m using OpenFoam 2.3.0
regards,
Naresh
Old   September 29, 2016, 16:37
Bruno Santos
Quick answers:
  1. Take a step back and create a simpler test case, similar to your geometry, but preferably one that means that it is a small test case that you can share with us, so it's easier to help you. This way it makes it easier to test things and diagnose any problems.
  2. After a quick re-search, I still haven't double-checked, but:
    1. createBaffles is always needed, but it essentially will assign faces inside the mesh from the faceZones that were created by snappyHexMesh.
    2. Boundary conditions can be assigned either:
      • manually inside the field files that you have inside the folder "0";
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
Time dependant pressure boundary condition yosuke1984 OpenFOAM Verification & Validation 3 May 6, 2015 06:16
Creating surface concentration boundary condition MachZero FLUENT 5 February 26, 2014 14:37
Radiation interface hinca CFX 15 January 26, 2014 17:11
boundary condition at free surface mike Fidelity CFD 3 June 8, 2006 06:23
