Leaking snappyHexMesh
Old   September 29, 2016, 05:37
Default Leaking snappyHexMesh
carno
Carno is on a distinguished road
Dear All,
I am trying to mesh an enclosure. I am using a closed volume for volume meshing and extracted surfaces for creating patches. There is 1 inlet and 1 outlet.
The problem is, if I mesh the volume without surface STLs as patches it meshes perfectly. As soon as I use extracted STL surfaces as patches it leaks, the same volume STL. I am attaching the two cases pictures.
geometry
    fixed.stl
        type triSurfaceMesh;
        name fixed;
        regions
              CFD_VOLUME_08             // Named region in the STL file
                  name wallsassy; // User-defined patch name
    inlet.stl
        name inlet;
    outlet.stl
        name outlet;
/*    canopy.stl
        name canopy;
As soon as I activate the canopy.stl, it starts leaking.
Kindly help..
Carno is offline   Reply With Quote
[CAD formats] Creating waterproof STL using snappyHexMesh or salome Tobi OpenFOAM Meshing & Mesh Conversion 58 May 13, 2020 06:01
[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. jasv OpenFOAM Meshing & Mesh Conversion 4 May 10, 2016 02:55
[snappyHexMesh] snappyhexmesh doesn't creat mesh in parallel issue? klausb OpenFOAM Meshing & Mesh Conversion 1 March 7, 2015 11:55
[snappyHexMesh] snappyHexMesh and blockMesh for internal flow (leaking geometry?) vaina74 OpenFOAM Meshing & Mesh Conversion 10 November 20, 2014 09:14
[snappyHexMesh] stitchMesh and snappyHexMesh gdbaldw OpenFOAM Meshing & Mesh Conversion 0 December 23, 2009 02:09
