k/omega boundary condition changed after decomposePar
Old   January 31, 2016, 08:26
Default k/omega boundary condition changed after decomposePar
Yage
Yage is on a distinguished road
Dear All,
I set the boundary condition for k/omega for walls, such as for k:
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0.04;
boundaryField
    frontAndBack
        type            symmetry;
    inlet
        type            fixedValue;
        value           $internalField;
    walls
        type            kqRWallFunction;
        value           uniform 0;
but the values in each processor is changed after decompose:
boundaryField
    frontAndBack
        type            symmetry;
    inlet
        type            fixedValue;
        value           nonuniform 0();
    blade
        value           uniform 0.04;
Any idea about this problem?
Regards,
Yage
Yage is offline   Reply With Quote
Old   January 31, 2016, 13:23
Retired Super Moderator
Bruno Santos
Quick answer: It's not a problem, it's a counter-measure to avoid shooting one's own foot.
"kqRWallFunction" is a boundary condition that is calculated by OpenFOAM itself and the provided value is for post-processing purposes.
If you were using 0, the solver would crash in the first iteration, because somewhere it would try to do a division by k=0.
Last edited by wyldckat; January 31, 2016 at 18:01. Reason: "try to a" --> "try to do a"
Old   January 31, 2016, 16:28
Yage
Dear Bruna,
thanks for your reply.
But the non-zero value will be also changed to internal field value, such as I use 1 instead of 0 for k at walls
Old   January 31, 2016, 20:05
Antimony is on a distinguished road
If you have specified a non-zero value for the value, then OpenFOAM would not change it to the internalField value.
My guess is that OpenFOAM replaces the value with internalField value (when the original value is zero) because it is the simplest estimate it can make based on the information it has.
Hope this helps.
Cheers,
Antimony
Antimony is offline   Reply With Quote
Old   February 4, 2016, 03:54
Yage
Originally Posted by Antimony View Post
Hope this helps.
Cheers,
Antimony
Dear Antimony,
Sorry for the later reply.
My openfoam version is 2.3.0 and the omega boundary value will change to internalfield value after decompose. But both of the values are non-zero. This is very strange.
One more question:
If I refine the mesh with added layers (y+<6), so that I dont need the wallfunction. then I should use fixedValue with uniform value=1e-10 for both k and omega, is that correct?
Regards,
Yage
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
conjugate boundary condition Daniel_Khazaei OpenFOAM Programming & Development 0 December 31, 2013 13:11
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
Opening Boundary Condition andreachan Main CFD Forum 11 March 19, 2013 16:46
