June 13, 2016, 01:50 |
issue decomposepar for parallel run.
Manu Chakkingal
Rep Power: 10 |
Hello
I am using bousinesqPimple Foam for heat transfer problem. When using the command decomeposepar it shows an error message wrt a file in 0 directory. I checked whether the filename has any whitespace,(tried replacing it aswell), (file T).But it shows the same error msg. COuld anyone let me know whats the issue. I am using OF 2.3.0 I face the same issue when trying to use foamToVTK for the results run in series simulation (same case).
Regards Manu |
June 13, 2016, 02:36 |
Nima Samkhaniani
Rep Power: 24 |
use following command
rm -rf 0/*~
My Personal Website (http://nimasamkhaniani.ir/) Telegram channel (https://t.me/cfd_foam) |
June 13, 2016, 02:39 |
Manu Chakkingal
Rep Power: 10 |
Thanks Nima..It worked
Regards Manu |
AVL start problem :MPI issue | gafoorcp | AVL FIRE | 1 | June 21, 2022 02:27 |
decomposePar no field transfert | Jeanp | OpenFOAM Pre-Processing | 3 | June 18, 2022 12:01 |
[mesh manipulation] Some questions on blockMesh, decomposePar and renumberMesh | Leech | OpenFOAM Meshing & Mesh Conversion | 19 | April 5, 2019 19:21 |
How to run decomposePar with parMetis? | xiaow_g | OpenFOAM Pre-Processing | 16 | July 8, 2017 13:37 |
[snappyHexMesh] Able to run snappyHexMesh in parallel on local machine but unable to run on linux clu | abhinav2601 | OpenFOAM Meshing & Mesh Conversion | 1 | January 26, 2015 05:42 |
