New Solver
Old   February 5, 2004, 06:29
Default Hello, How can I link a ne
Chalothon Thumthae (Thumthae)
How can I link a new solver to FoamX case manager, for example dieselEngineFoam or if I edit a new solver. For now, when I create a new case, the solver dieselEngineFoam is absent.
Thank
Torn
Old   February 5, 2004, 08:03
Default The configuration files for F
Chris Greenshields (Chris)
The configuration files for FoamX are in the $FOAMX_SYSTEM_CONFIG directory. They can be modified or added to. (In fact you can put personal changes in a directory $FOAMX_USER_CONFIG to avoid losing them during an upgrade of FOAM; $FOAMX_USER_CONFIG should have the same directory hierarchy as $FOAMX_SYSTEM_CONFIG)
dieselEngineFoam is the only solver that does not currently have a tutorial case or FoamX configuration associated with it (because it is very new). We will endeavour to supply a case and configuration in the next release of FOAM.
Old   October 28, 2005, 05:27
Default Hi, Where can I find the $FOA
Boris Deegen
borisd is on a distinguished road
Where can I find the $FOAM_SYSTEM_CONFIG directory? I have copy the FoamX file from the engineFoamsolver and now the dieselEngineFoam solver is listed in the FoamXCaseBrowser. It is able to open a case under dieselEngineFoam but how can I ceate the directories with spraymodel- or injector settings?
I need help.
Thank you
Boris
borisd is offline   Reply With Quote
Old   October 28, 2005, 05:32
Default Sorry, I would say dictionari
Boris Deegen
Sorry,
I would say dictionaries (like turbulencProperties) and not directories.
Old   November 27, 2006, 06:23
Default Hej, I have problems with a
mss
Hej,
I have problems with adding a user application class.
When typing "echo $FOAM_USER_CONFIG" I just receive a empty line as
answer....?
Could anyone help me with this problem?
thank you,
Rita
Old   February 8, 2009, 18:50
Default Dear All i successed to
Nugroho Adi
mahaputra is on a distinguished road
Dear All
i successed to make a new solver by using twoPhaseEulerFoam base solver. i called it as my_twoPhaseEulerFoam.
i put Temperature on it and i successed use it manually to simulate tutorial cases with Temperature on bed, bed2 and bubblecolumn without error message.
and i also try to put this new solver in FoamX. and success, it is shown in the solvers list.
but the problem is:
the Temperature ''feature'' that i put on the new solver doesnt show on the new case window that i made on FoamX. so i dont find Temperature column on the Fields list , for filling the Temperature boundary condition value (also in the Patch option)
is there anyone knows how to solve my problem?
please help me.
Regards
Nugroho Adi
mahaputra is offline   Reply With Quote
segregated solver vrs coupled solver sm FLUENT 0 November 6, 2007 01:24
How to do it if i change the seregated finitevolume solver to segregated finiteelement solver dandes OpenFOAM Pre-Processing 0 March 22, 2006 21:06
AGM-SOLVER MANOJ FLUENT 5 August 1, 2005 04:49
solver fuf FLUENT 0 June 19, 2003 13:54
coupled solver / uncoupled solver Jaan Unger Main CFD Forum 0 September 3, 2002 08:30
