pointVolInterpolation exists anymore?
Old   December 15, 2013, 13:14
Default pointVolInterpolation exists anymore?
ooo
ooo is on a distinguished road
Hi everybody,
I've already interpolated a volVectorField to a pointField successfully with "interpolation" class.
Now i want to interpolate the value of a pointField, to a volVectorField.
I've found that "pointVolInterpolation" can do it for me but i cannot find this file in :http://www.openfoam.org/docs/cpp/.
The volPointInterpolation can be found but not pointVolInterpolation!(it also cannot be found in the OpenFOAM's files in my computer)
Is there any alternative approach to do my job?
Thank you in advance.
ooo is offline   Reply With Quote
Old   December 15, 2013, 16:48
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Good evening OOO,
I have looked (quickly) in a couple of OF versions (1.6-ext, 1.7.1, 2.1.0 and 2.2.0) and it is only present in OF-1.6-ext, which indicates that you will not find it in the standard release.
Kind regards
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   December 15, 2013, 16:50
ooo
Originally Posted by ngj View Post
Good evening OOO,
Kind regards
Niels
Thank you but do you know how i can interpolate the value of a pointField, to a volVectorField?
Old   December 16, 2013, 01:03
ngj
I suggest that you look in the source code of 1.6-ext.
Kind regards
Niels
Old   December 29, 2013, 20:02
Retired Super Moderator
Bruno Santos
Greetings to all!
The correct class name should be "volPointInterpolation". You can find it by at the path given by this command:
echo $FOAM_SRC/finiteVolume/interpolation/volPointInterpolation
By the way, if anyone needs to have a single git repository of OpenFOAM with the whole public commit history (not the internal development version by OpenCFD ), check this post: http://www.cfd-online.com/Forums/ope...tml#post467684 post #12
Best regards,
Bruno
Cell_Function_Values: No post-processing value exists. jypark FLUENT 4 November 18, 2020 02:40
lduMatrix::debug does not work anymore in 2.2.1 AnjaMiehe OpenFOAM Programming & Development 3 October 15, 2018 10:46
refine mesh inside a block, water surface not smooth anymore JohnAB STAR-CCM+ 2 October 4, 2013 13:53
[GAMBIT] ERROR: The key, 0XAF8A, already exists in this HashTool fluent-user ANSYS Meshing & Geometry 2 February 11, 2013 19:17
exists minimum grid size for Ansys calculation? sooh2121 ANSYS 2 March 7, 2012 10:34
