blockMesh standalone?
Old   September 9, 2012, 10:14
Default blockMesh standalone?
ClayMayor is on a distinguished road
I would like to ask whether it's possible to compile blockMesh as a standalone application, on a system where I cannot have openFOAM installed. I have tried to toy around with separating dependencies and creating it's own makefile, but to no avail, I always end up with a ton of errors (if this is the right approach, I could send a list of files I've hunted down, but I kind of think it's not.) So I'm either completely missing something or am just being stupid and trying to do something what can't be done.
If this was already done and it's common knowledge, or I could have known by a simple search, then I'm terribly sorry for bothering you people with this thread, I always seem to pick exactly the wrong keywords when searching for something.
ClayMayor is offline   Reply With Quote
Old   September 10, 2012, 06:38
Mahdi Hosseinali
anishtain4 is on a distinguished road
I believe you can. First try by copying the files of block mesh and write a custom solver but don't change anything for it. when you do the wmake, there will be a dependency file created by the openfoam. in order to have your own stand alone utility you have to copy them all into the new computer. You should also do something about the wmake. or copy the compiled file from user_app_bin
anishtain4 is offline   Reply With Quote
Old   September 10, 2012, 07:37
akidess's Avatar
Anton Kidess
akidess will become famous soon enough
I believe your problem was already discussed in this thread: http://www.cfd-online.com/Forums/ope...xe-option.html
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
akidess is offline   Reply With Quote
Old   September 13, 2012, 06:50
Originally Posted by anishtain4 View Post
...or copy the compiled file from ser_app_bin
Yes. Just copy the executable. You know, now I really feel dumb. Since I have invested so much energy into it, I'll try to compile it anyway, so thank you both for your advice. Copying the executable will work even if I fail tho, so I think this is pretty much solved.
[blockMesh] blockMesh - help atareen64 OpenFOAM Meshing & Mesh Conversion 3 June 14, 2017 11:21
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
[blockMesh] tutorial 2.2 Stress(...) trouble with blockMesh colinB OpenFOAM Meshing & Mesh Conversion 8 January 22, 2012 10:32
Installation/Tutorial - libraries not found (blockMesh) bernarde OpenFOAM 3 June 19, 2009 12:36
Blockmesh cavity error message tonitoney OpenFOAM Installation 2 March 17, 2008 11:59
