September 13, 2012, 07:20 |
About surface normal Gradient
M Mallikarjuna Reddy
Rep Power: 13 |
Hi everyone,
I am fresher to openFoam. Now i am using openFoam 2.1.1 version. For my needs i need to apply zero flux at the walls for a scalar field. I am doing project on flow of suspensions (fluid and solid particles) through square channels. here i need to give zero flux at walls for the solid particle volume fraction. After applying this boundary condition i got an expression like dT/dy=f(velocity, T). where T=particle volume fraction(no units, scalar quantity). So for my case i need to give surface normal gradient. Please suggest me how to write code for it. Thanks Regards Mallikarjuna Last edited by mmkr825; September 14, 2012 at 13:11. |
How to get the surface normal vector | ohrmond | CFX | 3 | February 1, 2018 05:45 |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
UDF to Access Wall Normal Concentration Gradient | Daniel Tanner | Fluent UDF and Scheme Programming | 4 | February 18, 2015 14:35 |
[snappyHexMesh] Layers don't fully surround surface | EVBUCF | OpenFOAM Meshing & Mesh Conversion | 14 | August 20, 2012 04:31 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
