What does this Error mean?
Old   September 17, 2012, 08:22
Default What does this Error mean?
Christoph_84 is on a distinguished road
I programmed a Solver, witch works on one PC, now I want to compile the code on an other one and got this error:
nem@linux-81gf:~/OpenFOAM/nem-1.7.1/Solvers/StaubThermoDust_2D_Mix> wmake
 Making dependency list for source file StaubEx.C
 SOURCE=StaubEx.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-40 -I/opt/openfoam171/src/thermophysicalModels/basic/lnInclude     -I/opt/openfoam171/src/thermophysicalModels/specie/lnInclude     -I/opt/openfoam171/src/thermophysicalModels/basic/lnInclude     -I/opt/openfoam171/src/thermophysicalModels/reactionThermo/lnInclude     -I/opt/openfoam171/src/turbulenceModels/compressible/turbulenceModel     -I/opt/openfoam171/src/finiteVolume/cfdTools     -I/opt/openfoam171/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam171/src/OpenFOAM/lnInclude -I/opt/openfoam171/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/StaubEx.o
 /opt/openfoam171/src/finiteVolume/lnInclude/readPIMPLEControls.H: In Funktion »int main(int, char**)«:
 /opt/openfoam171/src/finiteVolume/lnInclude/readPIMPLEControls.H:12:10: Warnung: Variable »transonic« wird nicht verwendet
 g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-40 -I/opt/openfoam171/src/thermophysicalModels/basic/lnInclude     -I/opt/openfoam171/src/thermophysicalModels/specie/lnInclude     -I/opt/openfoam171/src/thermophysicalModels/basic/lnInclude     -I/opt/openfoam171/src/thermophysicalModels/reactionThermo/lnInclude     -I/opt/openfoam171/src/turbulenceModels/compressible/turbulenceModel     -I/opt/openfoam171/src/finiteVolume/cfdTools     -I/opt/openfoam171/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam171/src/OpenFOAM/lnInclude -I/opt/openfoam171/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed Make/linux64GccDPOpt/StaubEx.o -L/opt/openfoam171/lib/linux64GccDPOpt \
      -lbasicThermophysicalModels     -lspecie     -lcompressibleTurbulenceModel     -lcompressibleRASModels     -lcompressibleLESModels     -lfiniteVolume     -lmeshTools -lOpenFOAM -liberty -ldl   -lm -o /home/nem/OpenFOAM/nem-1.7.1/applications/bin/linux64GccDPOpt/StaubEx2DMix
 Make/linux64GccDPOpt/StaubEx.o: In function `main':
 StaubEx.C:(.text+0x3bf8): undefined reference to `Foam::hCombustionThermo::New(Foam::fvMesh const&)'
 collect2: ld gab 1 als Ende-Status zurück
 make: *** [/home/nem/OpenFOAM/nem-1.7.1/applications/bin/linux64GccDPOpt/StaubEx2DMix] Fehler 1
to test it i make a copy of rhoReactingFoam and try to compile this and got a similar error
nem@linux-81gf:~/OpenFOAM/nem-1.7.1/Solvers/rhoReactingFoam_test> wmake
 g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-40 -I/opt/openfoam171/src/turbulenceModels/compressible/turbulenceModel     -I/opt/openfoam171/src/thermophysicalModels/specie/lnInclude     -I/opt/openfoam171/src/thermophysicalModels/reactionThermo/lnInclude     -I/opt/openfoam171/src/thermophysicalModels/basic/lnInclude     -I/opt/openfoam171/src/thermophysicalModels/chemistryModel/lnInclude     -I/opt/openfoam171/src/ODE/lnInclude     -I/opt/openfoam171/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam171/src/OpenFOAM/lnInclude -I/opt/openfoam171/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed Make/linux64GccDPOpt/rhoReactingFoam.o -L/opt/openfoam171/lib/linux64GccDPOpt \
      -lbasicThermophysicalModels     -lspecie     -lcompressibleTurbulenceModel     -lcompressibleRASModels     -lcompressibleLESModels     -lfiniteVolume     -lmeshTools -lOpenFOAM -liberty -ldl   -lm -o /home/nem/OpenFOAM/nem-1.7.1/applications/bin/linux64GccDPOpt/rhoReactingFoam_test
 Make/linux64GccDPOpt/rhoReactingFoam.o: In function `main':
 rhoReactingFoam.C:(.text+0x23a8): undefined reference to `Foam::rhoChemistryModel::New(Foam::fvMesh const&)'
 make: *** [/home/nem/OpenFOAM/nem-1.7.1/applications/bin/linux64GccDPOpt/rhoReactingFoam_test] Fehler 1
What does this mean and how I can solve it?
Christoph
Christoph_84 is offline   Reply With Quote
Old   September 17, 2012, 09:17
Retired Super Moderator
Bruno Santos
Greetings Christoph,
Are both machines using the same version of OpenFOAM?
Best regards,
Bruno
Old   September 17, 2012, 09:55
Yes, both 1.7.1, I have now solved the problem by recompiling OpenFoam. It seams that the computer wasn’t set up properly.
Christoph
