adding "h" field to sonicFoam
Like Tree1Likes
  • 1 Post By wyldckat
Old   June 15, 2013, 09:38
Default adding "h" field to sonicFoam
immortality's Avatar
Ehsan
immortality is on a distinguished road
Hi
how can add "h" field to sonicFoam?
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   June 15, 2013, 11:00
Retired Super Moderator
Bruno Santos
Hi Ehsan,
It depends on how exactly you want to calculate the field "h" and if it should affect the flow of the fluid as well or not.
I did a bit of searching and this does not look like to be an easy task, at least according to this bug report: http://www.openfoam.org/mantisbt/view.php?id=86
Best regards,
Bruno
Old   June 15, 2013, 11:20
Ehsan
Hi dear Bruno
it only suffice that be calculated through e,p nd rho as you know:h=e+p/rho
and doesn't affect the flow.is it difficult to define a field for that so that it obtains from three other fields(e,p,rho)?
Old   June 15, 2013, 11:46
Bruno Santos
Mmm... the "e" is a field that already exists... OK, try adding the following code, after the equation for "e" is solved:
volScalarField h
    IOobject
         "h",
         runTime.timeName(),
         mesh,
         IOobject::MUST_READ,
         IOobject::AUTO_WRITE
     mesh,
     e+p/rho
I based myself on this tutorial: http://openfoamwiki.net/index.php/Ho...ure_to_icoFoam - but I have not tested it.
Old   June 15, 2013, 11:57
Ehsan
you mean in createFields,right?
where it should be exactly added?
Info<< "Reading thermophysical properties\n" << endl;
    autoPtr<psiThermo> pThermo
        psiThermo::New(mesh)
    psiThermo& thermo = pThermo();
    thermo.validate(args.executable(), "e");
    volScalarField& p = thermo.p();
    volScalarField& e = thermo.he();
    const volScalarField& psi = thermo.psi();
    volScalarField rho
        IOobject
            "rho",
            runTime.timeName(),
            mesh
        thermo.rho()
    Info<< "Reading field U\n" << endl;
    volVectorField U
        IOobject
            "U",
            runTime.timeName(),
            mesh,
        mesh
    Info<< "Reading field gas\n" << endl;
    volScalarField gas
        IOobject
            "gas",
            runTime.timeName(),
            mesh,
        mesh
    #include "compressibleCreatePhi.H"
    Info<< "Creating turbulence model\n" << endl;
    autoPtr<compressible::turbulenceModel> turbulence
        compressible::turbulenceModel::New
            rho,
            U,
            phi,
            thermo
Old   June 15, 2013, 12:00
Bruno Santos
No, no... I said after solving the equation "e"... this means in "eEqn.H", if I'm not mistaken on the name of the file.
Old   June 15, 2013, 12:47
Ehsan
is it true?
    solve
        fvm::ddt(rho, e)
      + fvm::div(phi, e)
      - fvm::laplacian(turbulence->alphaEff(), e)
      - p*fvc::div(phi/fvc::interpolate(rho))
    thermo.correct();
volScalarField h
    IOobject
         "h",
         runTime.timeName(),
         mesh,
     mesh,
     e+p/rho
Old   June 15, 2013, 12:51
Ehsan
Bruno its the error:
ehsan@Ehsan-com:~/Desktop/Solvers/sonicFoamWGMaxCo_220$ wmake
Making dependency list for source file sonicFoamModified.C
SOURCE=sonicFoamModified.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/opt/openfoam220/src/thermophysicalModels/basic/lnInclude -I/opt/openfoam220/src/turbulenceModels/compressible/turbulenceModel -I/opt/openfoam220/src/finiteVolume/lnInclude -I/opt/openfoam220/src/finiteVolume/cfdTools -I/opt/openfoam220/src/meshTools/lnInclude -I/opt/openfoam220/src/sampling/lnInclude -I/opt/openfoam220/src/fvOptions/lnInclude -IlnInclude -I. -I/opt/openfoam220/src/OpenFOAM/lnInclude -I/opt/openfoam220/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/sonicFoamModified.o
In file included from sonicFoamModified.C:64:0:
eEqn.H: In function ‘int main(int, char**)’:
eEqn.H:25:1: error: no matching function for call to ‘Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject, Foam::fvMesh&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >)’
eEqn.H:25:1: note: candidates are:
/opt/openfoam220/src/OpenFOAM/lnInclude/GeometricField.C:605:1: note: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Foam::GeometricField<Type, PatchField, GeoMesh>&, const wordList&, const wordList&) [with Type = double, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh, Foam::wordList = Foam::List<Foam::word>]
/opt/openfoam220/src/OpenFOAM/lnInclude/GeometricField.C:605:1: note:   no known conversion for argument 2 from ‘Foam::fvMesh’ to ‘const Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&’
/opt/openfoam220/src/OpenFOAM/lnInclude/GeometricField.C:570:1: note: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Foam::GeometricField<Type, PatchField, GeoMesh>&, const Foam::word&) [with Type = double, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh]
/opt/openfoam220/src/OpenFOAM/lnInclude/GeometricField.C:570:1: note:   no known conversion for argument 2 from ‘Foam::fvMesh’ to ‘const Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&’
/opt/openfoam220/src/OpenFOAM/lnInclude/GeometricField.C:540:1: note: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::word&, const Foam::tmp<Foam::GeometricField<Type, PatchField, GeoMesh> >&) [with Type = double, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh]
/opt/openfoam220/src/OpenFOAM/lnInclude/GeometricField.C:540:1: note:   candidate expects 2 arguments, 3 provided
/opt/openfoam220/src/OpenFOAM/lnInclude/GeometricField.C:507:1: note: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::word&, const Foam::GeometricField<Type, PatchField, GeoMesh>&) [with Type = double, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh]
/opt/openfoam220/src/OpenFOAM/lnInclude/GeometricField.C:507:1: note:   candidate expects 2 arguments, 3 provided
/opt/openfoam220/src/OpenFOAM/lnInclude/GeometricField.C:475:1: note: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Foam::GeometricField<Type, PatchField, GeoMesh>&) [with Type = double, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh]
/opt/openfoam220/src/OpenFOAM/lnInclude/GeometricField.C:475:1: note:   candidate expects 2 arguments, 3 provided
/opt/openfoam220/src/OpenFOAM/lnInclude/GeometricField.C:444:1: note: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::tmp<Foam::GeometricField<Type, PatchField, GeoMesh> >&) [with Type = double, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh]
/opt/openfoam220/src/OpenFOAM/lnInclude/GeometricField.C:444:1: note:   candidate expects 1 argument, 3 provided
/opt/openfoam220/src/OpenFOAM/lnInclude/GeometricField.C:412:1: note: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::GeometricField<Type, PatchField, GeoMesh>&) [with Type = double, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh]
/opt/openfoam220/src/OpenFOAM/lnInclude/GeometricField.C:412:1: note:   candidate expects 1 argument, 3 provided
/opt/openfoam220/src/OpenFOAM/lnInclude/GeometricField.C:371:1: note: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Mesh&, const Foam::dictionary&) [with Type = double, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh, Foam::GeometricField<Type, PatchField, GeoMesh>::Mesh = Foam::fvMesh]
/opt/openfoam220/src/OpenFOAM/lnInclude/GeometricField.C:371:1: note:   no known conversion for argument 3 from ‘Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >’ to ‘const Foam::dictionary&’
/opt/openfoam220/src/OpenFOAM/lnInclude/GeometricField.C:331:1: note: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Mesh&) [with Type = double, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh, Foam::GeometricField<Type, PatchField, GeoMesh>::Mesh = Foam::fvMesh]
/opt/openfoam220/src/OpenFOAM/lnInclude/GeometricField.C:331:1: note:   candidate expects 2 arguments, 3 provided
/opt/openfoam220/src/OpenFOAM/lnInclude/GeometricField.C:304:1: note: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Mesh&, const Foam::dimensionSet&, const Foam::Field<TypeR>&, const Foam::PtrList<PatchField<Type> >&) [with Type = double, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh, Foam::GeometricField<Type, PatchField, GeoMesh>::Mesh = Foam::fvMesh]
/opt/openfoam220/src/OpenFOAM/lnInclude/GeometricField.C:304:1: note:   candidate expects 5 arguments, 3 provided
/opt/openfoam220/src/OpenFOAM/lnInclude/GeometricField.C:274:1: note: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Mesh&, const Foam::dimensioned<Form>&, const wordList&, const wordList&) [with Type = double, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh, Foam::GeometricField<Type, PatchField, GeoMesh>::Mesh = Foam::fvMesh, Foam::wordList = Foam::List<Foam::word>]
/opt/openfoam220/src/OpenFOAM/lnInclude/GeometricField.C:274:1: note:   candidate expects 5 arguments, 3 provided
/opt/openfoam220/src/OpenFOAM/lnInclude/GeometricField.C:245:1: note: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Mesh&, const Foam::dimensioned<Form>&, const Foam::word&) [with Type = double, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh, Foam::GeometricField<Type, PatchField, GeoMesh>::Mesh = Foam::fvMesh]
/opt/openfoam220/src/OpenFOAM/lnInclude/GeometricField.C:245:1: note:   no known conversion for argument 3 from ‘Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >’ to ‘const Foam::dimensioned<double>&’
/opt/openfoam220/src/OpenFOAM/lnInclude/GeometricField.C:217:1: note: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Mesh&, const Foam::dimensionSet&, const wordList&, const wordList&) [with Type = double, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh, Foam::GeometricField<Type, PatchField, GeoMesh>::Mesh = Foam::fvMesh, Foam::wordList = Foam::List<Foam::word>]
/opt/openfoam220/src/OpenFOAM/lnInclude/GeometricField.C:217:1: note:   candidate expects 5 arguments, 3 provided
/opt/openfoam220/src/OpenFOAM/lnInclude/GeometricField.C:187:1: note: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Mesh&, const Foam::dimensionSet&, const Foam::word&) [with Type = double, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh, Foam::GeometricField<Type, PatchField, GeoMesh>::Mesh = Foam::fvMesh]
/opt/openfoam220/src/OpenFOAM/lnInclude/GeometricField.C:187:1: note:   no known conversion for argument 3 from ‘Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >’ to ‘const Foam::dimensionSet&’
/opt/openfoam220/src/finiteVolume/lnInclude/readPISOControls.H:3:15: warning: unused variable ‘nOuterCorr’ [-Wunused-variable]
/opt/openfoam220/src/finiteVolume/lnInclude/readPISOControls.H:12:16: warning: unused variable ‘momentumPredictor’ [-Wunused-variable]
/opt/openfoam220/src/finiteVolume/lnInclude/readPISOControls.H:15:16: warning: unused variable ‘transonic’ [-Wunused-variable]
make: *** [Make/linux64GccDPOpt/sonicFoamModified.o] Error 1
Old   June 15, 2013, 13:04
Bruno Santos
I'm trying this myself and it doesn't work. "p/rho" doesn't have the same units as "e" (edit: or structure?).
But I've just now remembered something... what thermal properties have you defined for your case?
Because the "e" field is in fact "thermo.he()", which means that it can be "h", depending on the options, therefore not requiring any additional coding.
Old   June 15, 2013, 13:45
Ehsan
yes they both have the same dimension.
no it doesn't accept enthalpy as the bug link you gave confirm it.maybe can replace it by R*T that R is approximately 287.14 for air
is it possible?
in general adding a new field from existing fields doesn't have a routine method?
Old   June 15, 2013, 15:07
Bruno Santos
Hi Ehsan,
Sorry, but something strange happened back then. I know that compiling went wrong when using "h = e + p/rho", but now it's working... very strange ...
OK, the modifications I did were as follows:
  1. Edit the file "createFields.H" and append the following code:
        volScalarField h
            IOobject
                "h",
                runTime.timeName(),
                mesh,
                IOobject::NO_READ,
            e
    Note: "e" instead of "mesh" is for initializing the field with the same dimensions.
  2. Then edit the file "eEqn.H" and add this line before the last "}":
    h = e + p/rho;
  3. Don't forget to save the files (I might have forgotten to do this step a few hours ago ).
Then run:
wmake
And this is all it takes!
_____________
In regards to the initial idea, I had forgotten that the following:
volScalarField h
    IOobject
         "h",
         runTime.timeName(),
         mesh,
     mesh,
     e+p/rho
should only be used when:
  1. The "e+p/rho" gave only a dimensioned scalar, not a complete dimensioned scalar field.
  2. "MUST_READ" would have given you troubles, since you only wanted to calculate it after everything was done...
Best regards,
Bruno
immortality likes this.
problems after decomposing for running alessio.nz OpenFOAM 7 March 5, 2021 04:49
Adding Temperature field to IcoFoam yapalparvi OpenFOAM Programming & Development 14 November 19, 2015 04:57
Field functions and table crevoise Siemens 0 March 20, 2013 10:51
Error trying to run steady-state sonicFoam dancfd OpenFOAM Running, Solving & CFD 2 February 12, 2013 03:15
Adding temperature field to InterFoam yapalparvi OpenFOAM Running, Solving & CFD 8 October 14, 2009 20:18
