coupledMatrix and RegionCoupling - urgent
Like Tree2Likes
  • 1 Post By wyldckat
Old   June 16, 2013, 08:28
Default coupledMatrix and RegionCoupling - urgent
mahdi abdollahzadeh
mm.abdollahzadeh is on a distinguished road
Dear All
I have compiled coupledmatrix and regioncoupling patches from openfoam 1.6ext in openfoam 2.1x successfully.
now Im trying t test the conjucatecavity tutorial for it. But there comes a problem
--> FOAM FATAL ERROR:
Unknown patch field type regionCouple
Valid patchField types are :
13
processor
nonuniformTransformCyclic
processorCyclic
wedge
fixedValue
empty
cyclicAMI
cyclicSlip
calculated
regionCoupling
symmetryPlane
sliced
cyclic
    From function fvsPatchField<Type>::New
I dont know how can I solve it.
I appreciate any idea.
Best
Mahdi
mm.abdollahzadeh is offline   Reply With Quote
Old   June 16, 2013, 09:16
Retired Super Moderator
Bruno Santos
Hi Mahdi,
Quick answer - read the subsection "3.2.6 Linking new user-defined libraries to existing applications" on the OpenFOAM User Guide: http://www.openfoam.org/docs/user/co...plications.php
Best regards,
Bruno
mm.abdollahzadeh likes this.
Old   June 16, 2013, 09:24
mahdi abdollahzadeh
Hi Bruno
Thanks for the link.I have compiled them as a part of openfoam library not user library. just to explain my more my problem the problem is arising from this line of fvsPatchfieldNew.C when creating phi.
   typename patchConstructorTable::iterator cstrIter =
        patchConstructorTablePtr_->find(patchFieldType);
    if (cstrIter == patchConstructorTablePtr_->end())
        FatalErrorIn
            "fvsPatchField<Type>::New(const word&, const word&, const fvPatch&"
            ", const Field<Type>&)"
        )   << "Unknown patchField type "
            << patchFieldType << nl << nl
            << "Valid patchField types are :" << endl
            << patchConstructorTablePtr_->sortedToc()
            << exit(FatalError);
best
Mahdi
Old   June 16, 2013, 09:28
Bruno Santos
Hi Mahdi,
I took a better look at the first post... shouldn't the name to be used be "regionCoupling" and not "regionCouple"?
Best regards,
Bruno
Old   June 16, 2013, 09:37
mahdi abdollahzadeh
Many thanks for your kind answer Bruno
Regioncouple is the name of regioncouplepolypatch and regioncouplefvpatch.
regiongcoupling is the name of fieldpatches.
regioncouple patches are based on couplefvpatch. as mentioned here by HRv for openfoam extended, http://www.cfd-online.com/Forums/openfoam-solving/57847-coupled-regions.html,
there is sth that is forcing that name of the patch and field should be the same. I checked the corresponding code in openfoam 1.6ext and openfoam 2.1x but i didnt understand where I can solve it.
just i should mention that regioncoupling in openfoam 1.6ext is working.
best
Mahdi
Old   June 16, 2013, 11:00
Bruno Santos
Hi Mahdi,
Mmm... I've taken a look into the source code of 1.6-ext and I found that the file "src/finiteVolume/fields/fvsPatchFields/constraint/regionCouple/regionCoupleFvsPatchField.H" has the following code:
public:
    //- Runtime type information
//     TypeName(regionCoupleFvPatch::typeName_());
    TypeName("regionCoupling");
On 1.5-dev it's still the exact same thing: http://sourceforge.net/p/openfoam-ex...tchField.H#l81
So, it's no wonder that "regionCouple" doesn't show up in the list And this probably means that Hrv hasn't fixed this yet, at least on these versions...
Best regards,
Bruno
Old   June 16, 2013, 11:04
mahdi abdollahzadeh
Hi Burono,
Thanks for checking the codes. But if it is not fixed, how i can run the code in openfoam1.6ext?!
Best
Mahdi
Old   June 16, 2013, 11:11
Bruno Santos
Hi Mahdi,
Probably there is a hack somewhere in 1.6-ext that forces the loading of the correct class?
Best regards,
Bruno
Old   June 16, 2013, 13:14
mahdi abdollahzadeh
Hi Bruno
I think that should be hard for me to do.
I check the patch type, there is a bool attach , if i make it false, it will pass the privious error but it will blows after the first iteration.
Best
Mahdi
Old   June 16, 2013, 13:29
Bruno Santos
Hi Mahdi,
Have you tried changing:
To:
TypeName("regionCouple");
in "src/finiteVolume/fields/fvsPatchFields/constraint/regionCouple/regionCoupleFvsPatchField.H", but only for your version in 2.1.x?
Best regards,
Bruno
Old   June 16, 2013, 14:21
mahdi abdollahzadeh
Many thanks Burono,
Yes I have did it. but I got this
Reading field p
--> FOAM FATAL IO ERROR:
inconsistent patch and patchField types for
    patch type regionCouple and patchField type zeroGradient
file: /home/mahdi/OpenFOAM/mahdi-2.1.x/applications/conjugateCavity/0/p::boundaryField::right from line 35 to line 35.
    From function fvPatchField<Type>::New(const fvPatch&, const DimensionedField<Type, volMesh>&, const dictionary&)
    in file /home/mahdi/OpenFOAM/OpenFOAM-2.1.x/src/finiteVolume/lnInclude/fvPatchFieldNew.C at line 164.
FOAM exiting
Segmentation fault
best
mahdi
