volScalarField to power of constant
Like Tree8Likes
  • 7 Post By PicklER
  • 1 Post By ngj
Old   August 13, 2014, 07:34
Default volScalarField to power of constant
PicklER is on a distinguished road
Hello (my first post)
I want to calculate:
rS=a0*P^rbn
in OpenFOAM, for a modified version of rhoCentralFoam. Where:
rS (0 1 -1 0 0 0 0) speed (m/s) volScalarField created by createFields
a0 (-1 2 1 0 0 0 0) read from thermophysicalProperties in test case as dimensionedScalar
P (1 -1 -2 0 0 0 0) pressure (kg/(ms^2)) created by createFields
rbn read from thermophysicalProperties in test case as dimensionedScalar, but is dimensionless and is some constant.
If I multiply a0 with P, then the dimensions change to (0 1 -1 0 0 0 0), which is correct for rS (0 1 -1 0 0 0 0) speed (m/s) volScalarField.
My problem is when I do P^rbn by using pow(P,rbn). Then the dimensions are altered.
My question: Is there a way to take a volScalarField such as P, to the power of a dimensionless scalar such as rbn without changing the dimensions??
Kind regards
PicklER is offline   Reply With Quote
Old   August 19, 2014, 03:11
I got a way to do this:
Store the dimensions of "p" as arDims
dimensionSet arDims(p.dimensions());
Make "p" dimensionless
p.dimensions().reset(dimless);
Perform calculation (resulting in desired dimension) (0 1 -1 0 0 0 0)
ar = a0*pow(p,rbn);
Restore the dimensions of "p".
p.dimensions().reset(arDims);
Hope this will help someone.
Vrede
Old   August 21, 2014, 08:42
Joachim Herb
jherb is on a distinguished road
Have you tried to use: p.value()
This should give you the dimensionless values of the pressure field.
jherb is offline   Reply With Quote
Old   August 21, 2014, 13:59
Hi jherb
Yes, I have tried "p.value()" (result below) and "p.val()", just to make sure.
srmFoamLam.C: In function ‘int main(int, char**)’:
srmFoamLam.C:88:23: error: ‘Foam::volScalarField’ has no member named ‘value’
  Info << "p.val "<< p.value() << endl;
Thanks for idea though
Vrede
Old   August 21, 2014, 15:47
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hallo,
One approach would be to do the following:
scalar exponent = 1.5;
// Perform on the internal part of the field
p.internalField() = Foam::pow(p.internalField(), exponent);
// Perform on the boundaries
forAll (p.boundaryField(), patchi)
    scalarField& pw = p.boundaryField()[patchi];
    pw = Foam::pow(pw, exponent);
p.correctBoundaryConditions();
Kind regards,
Niels
Luttappy likes this.
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   August 22, 2014, 15:44
Joachim Herb
Ok, googling I found: http://www.cfd-online.com/Forums/ope...tml#post476693
The correct method seems to be field()
constant), pow(volscalarfield
make a dimensionedScalar to be volScalarField sharonyue OpenFOAM Programming & Development 4 April 2, 2014 05:44
writing execFlowFunctionObjects immortality OpenFOAM Post-Processing 30 September 15, 2013 06:16
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 18:44
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 06:25
Really big problems when creating own materials da Jop FLUENT 0 June 28, 2007 11:15
