Problem in Implementing a non-linear SGS model
Like Tree1Likes
Old   February 4, 2015, 14:37
Retired Super Moderator
Bruno Santos
Originally Posted by zoptirik View Post
but it gave me compalition error (error 1)
Quick answer:
  1. Use the package from post #13
  2. Provide more details on the exact steps you've used.
  3. Please indicate which OpenFOAM version you're using.
Old   February 8, 2015, 07:12
karar
zoptirik is on a distinguished road
Originally Posted by wyldckat View Post
Quick answer:
Hi wyldckat
I used the package from post 13, i followed the way that u said post 13. first unpack than build cd nonlinearLESkit ./Allwmake... after compilation
generic@generic-M4700:~/OpenFOAM/generic-2.3.0/src/turbulenceModels/incompressible/nonlinearLESkit$ ./Allwmake
wmakeLnInclude: linking include files to ./lnInclude
Making dependency list for source file LESNonlinearModel.C
Making dependency list for source file GennonlinearSGS.C
SOURCE=LESNonlinearModel.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/opt/openfoam230/src/turbulenceModels -I/opt/openfoam230/src/turbulenceModels/LES/LESdeltas/lnInclude -I/opt/openfoam230/src/turbulenceModels/LES/LESfilters/lnInclude -I/opt/openfoam230/src/transportModels -I/opt/openfoam230/src/finiteVolume/lnInclude -I/opt/openfoam230/src/meshTools/lnInclude -IlnInclude -I. -I/opt/openfoam230/src/OpenFOAM/lnInclude -I/opt/openfoam230/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/LESNonlinearModel.o
SOURCE=GennonlinearSGS.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/opt/openfoam230/src/turbulenceModels -I/opt/openfoam230/src/turbulenceModels/LES/LESdeltas/lnInclude -I/opt/openfoam230/src/turbulenceModels/LES/LESfilters/lnInclude -I/opt/openfoam230/src/transportModels -I/opt/openfoam230/src/finiteVolume/lnInclude -I/opt/openfoam230/src/meshTools/lnInclude -IlnInclude -I. -I/opt/openfoam230/src/OpenFOAM/lnInclude -I/opt/openfoam230/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/GennonlinearSGS.o
'/home/generic/OpenFOAM/generic-2.3.0/platforms/linux64GccDPOpt/lib/libLESNonlinearModels.so' is up to date.
Making dependency list for source file Smagorinsky.C
SOURCE=Smagorinsky.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/opt/openfoam230/src/turbulenceModels -I/opt/openfoam230/src/turbulenceModels/LES/LESdeltas/lnInclude -I/opt/openfoam230/src/turbulenceModels/LES/LESfilters/lnInclude -I/opt/openfoam230/src/transportModels -I/opt/openfoam230/src/finiteVolume/lnInclude -I/opt/openfoam230/src/meshTools/lnInclude -I../LESNonlinear/lnInclude -IlnInclude -I. -I/opt/openfoam230/src/OpenFOAM/lnInclude -I/opt/openfoam230/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/Smagorinsky.o
In file included from ../LESNonlinear/lnInclude/GennonlinearSGS.H:42:0,
                 from Smagorinsky.H:53,
                 from Smagorinsky.C:26:
../LESNonlinear/lnInclude/LESNonlinearModel.H: In static member function ‘static Foam::autoPtr<Foam::incompressible::LESNonlinearModel> Foam::incompressible::LESNonlinearModel::adddictionaryConstructorToTable<LESNonlinearModelType>::New(const volVectorField&, const surfaceScalarField&, Foam::transportModel&, const Foam::word&) [with LESNonlinearModelType = Foam::incompressible::LESNonlinearModels::Smagorinsky, Foam::volVectorField = Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>, Foam::surfaceScalarField = Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>]’:
../LESNonlinear/lnInclude/LESNonlinearModel.H:115:9:   instantiated from ‘Foam::incompressible::LESNonlinearModel::adddictionaryConstructorToTable<LESNonlinearModelType>::adddictionaryConstructorToTable(const Foam::word&) [with LESNonlinearModelType = Foam::incompressible::LESNonlinearModels::Smagorinsky]’
Smagorinsky.C:41:1:   instantiated from here
../LESNonlinear/lnInclude/LESNonlinearModel.H:115:9: error: cannot allocate an object of abstract type ‘Foam::incompressible::LESNonlinearModels::Smagorinsky’
Smagorinsky.H:68:7: note:   because the following virtual functions are pure within ‘Foam::incompressible::LESNonlinearModels::Smagorinsky’:
/opt/openfoam230/src/turbulenceModels/incompressible/turbulenceModel/turbulenceModel.H:217:37: note:     virtual Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > > Foam::incompressible::turbulenceModel::divDevRhoReff(const volScalarField&, Foam::volVectorField&) const
../LESNonlinear/lnInclude/LESNonlinearModel.H:115:9: warning: control reaches end of non-void function [-Wreturn-type]
make: *** [Make/linux64GccDPOpt/Smagorinsky.o] Error 1
Openfoam version is 2.3.0
zoptirik is offline   Reply With Quote
Old   February 10, 2015, 06:35
karar
I tried to compile the files separately. LESNonlinear file was compiled successfuly. But when i tried to compile SM-non, it gave me following error
Old   March 2, 2015, 07:38
karar
Hi All
As i said before I am dealing with the SGS stress instead of the eddy viscosity. i tried to compiled nonlinearLEskit, but it gave me compalition error. I couldnt solve the error. Therefore I have used to DeardorffDiffStress based on GenSGSStress. but this model also use nu_sgs in the calculation of divDevReff(U). for making same things with nonlinearLEskit in the computation of divdevreff, i product 0 to nu_sgs term as follows
 nuSgs_ = 0*rho()*sqrt(K)*delta()
Could I have done something wrong?
Best
Old   March 19, 2015, 03:34
Huang Xianbei
huangxianbei is on a distinguished road
sorry for the late reply. This may be solved when you turn on the debug mode. I can compile this when debug mode is turned on, although I didn't find any error in opti mode on another computer. This is strange, but this may overcome this problem. Anthoer solution may be changing the OF version, to 2.1.1 as I used.
I'm not sure if you have solved your problem, but I have a question that you may also face: how to implement a wall function for nonlinear models?
As in OF, the nuSgs wall function is implemented to correct the turbulent viscosity, however, if as I have done, the SGS stress is treated instead of the turbulent viscosity, so this method can't be used in the nonlinear models.
Do you have any suggestions?
Xianbei
huangxianbei is offline   Reply With Quote
Old   May 19, 2015, 13:30
Timm Severin
Astrodan is on a distinguished road
Oh, the missing important detail is that this line:
    constructdictionaryConstructorTables();
It was missing from the "LESNonlinearModel::New" method... although I haven't figured out why "LESModel" doesn't need this hack... I'll dig deeper and edit this post to report back if I can figure it out.
edit: OK, I've figured it out. When optimized, there are some-things that aren't called because it's non-optimal to call something that isn't going to be used in the first place. This might not be the exact situation in this case, but it's probably very close to the truth.
So, if the example simulation case has this entry in the "controlDict" file:
libs
  "libSmagorinsky.so"
it will enforce that the table is constructed in order to add the very first new model. If no models were added, then the table would not be constructed in the first place. This pretty much happens in the file "Smagorinsky.C", in this line:
addToRunTimeSelectionTable(LESNonlinearModel, Smagorinsky, dictionary);
which will construct said table for the first time.
Best regards,
Bruno
Hey Bruno & Xianbei,
I just had the same problem with an empty constructorTablePtr_, and it took me 2h to debug and finally find this thread here. It really did annoy me, because I was sure there was nothing wrong, and checked my code five times anyway.. and the stack message is not really helpful.
Do you have any idea if there is any OF-internal possibility to catch this error? I can work with the runTimeSelection interface, but I'm not really familiar, so I don't know where this check could be placed..
PhD Student at the Institute of Biochemical Engineering at TU München
Modelling of fluid dynamics in open photobioreactors.
System:
OpenFOAM 2.3.x, 64bit, 8 Core Xeon Workstation
Astrodan is offline   Reply With Quote
Old   May 21, 2015, 16:29
Bruno Santos
Quick answer: If you can give us a clear example of what you're trying to fix/solve/catch, it would make it a lot easier to diagnose/search for the solution.
I ask this because I wrote that post 4 months ago and I barely remember what it was all about
Old   May 24, 2015, 11:55
Timm Severin
Sorry, I just read it, so this seemed obvious. My Problem is that this line
dictionaryConstructorTable::iterator cstrIter = dictionaryConstructorTablePtr_->find(exampleType);
produces a segmentation fault when there is no model in the list, as you described:
Whoever wants to reproduce, I attached an example objet library and a solver that creates such an object.
Just compile (./Allwmake) and run exampleFoam.
The error occurs in lib/exampleBaseClassNew.C:18:
Selecting exampleType randomClass
Veni...
Vidi...
Segmentation fault (core dumped)
(Where Veni vidi vici would be my oldschool debug output)
System:
Old   May 24, 2015, 16:28
Bruno Santos
Quick answer: There is no attachment in your post
Old   May 26, 2015, 03:33
Timm Severin
Reasonable argument. Apparently this thread has some negative influence on my concentration .
I uploaded the file and added some additional notes at the end of the last post.
System:
Old   September 20, 2015, 13:26
Bruno Santos
Greetings to all!
OK, this was on my to-do list since... March of this year? And I've finally managed to look into this.
I've used the code from my post #13 and started a new repository for handling all of the modifications of this proof of concept: https://github.com/wyldckat/nonlinearLESkit
The repository now provides the source code adapted to work on:
  • OpenFOAM 2.1.1, which is the source code from post #13.
  • OpenFOAM 2.1.x
  • OpenFOAM 2.3.x - which should work with OpenFOAM versions 2.3.0 to 2.3.x and possibly with OpenFOAM 2.2.
Instructions on how to download and build are provided on the front-page of the project.
Best regards,
Bruno
cfdonline2mohsen likes this.
Two way Fsi Problem- Non linear problem kmgraju CFX 4 April 28, 2015 11:15
the combustion model problem hanshandiaoke STAR-CD 7 December 2, 2011 03:47
the combustion model problem hanshandiaoke Siemens 0 November 25, 2011 20:37
Problem in Buoyancy Model? dhrubo CFX 3 June 5, 2010 05:32
solution diverges when linear upwind interpolation scheme is used subash OpenFOAM 0 May 29, 2010 01:23
